Super star pads del...
[Closed] Super star pads delaminateing yet again...
robdeanhove - Member
What? Well, yes, you really should oil your pads to prevent corrosion, just like you do your chain. Or maybe just some WD40 after a ride or when you've cleaned it to disperse the worst of the water! :-S
Very amusing. Actually, what you should do if a component becomes badly corroded is replace it, especially if it's a safety-critical part, rather than waiting for the inevitable failure then complaining on the internet about it.
Or, if you're using them in a very salty environment, which I assume must be the case here if the condition's genuine, you ought to give the poor bike a hose down and clean occasionally.
Posted : 31/01/2012 4:04 pm
Glittergary - SSC stated there was a rogue batch that caused the issues of de-laminating pads and that this was not going to happen again. People continued to get pads that de laminated after this "rogue batch" was "removed" from sale
the "nastyness" from Mlehworld was because he ripped off and mocked 3 memebers with cranksets and then lied about it.
Posted : 31/01/2012 4:08 pm
Yep, tbh I think it's fair to say that in the bike industry, it's practically never a bad batch, it's just a convenient feeble excuse.
Posted : 31/01/2012 4:24 pm
OP, where do you ride? On the bed of the North Sea?
Theres less corrosion on the Titanic...
Posted : 31/01/2012 8:15 pm
Has Mrs fruit raced against our jojo yet?
Posted : 31/01/2012 9:19 pm
*waves at Bruce*
Posted : 31/01/2012 9:26 pm
*gesticulates in return*
I think I'll start a new brake maintenance regime. Wash, rinse and blow dry after every ride, spray brakes with WD40 and set fire to it, and then shine the disc with wax car polish. That should keep the kit nice and dry.
To think I've been carelessly leaving them to rust since my first 'agricultural' C2s about twelve years ago. I've been so lucky.
Posted : 31/01/2012 11:51 pm
Do you think that's normal everyday corrosion on those? Seriously? Even the sets I've used for winter road use have never got anything like that. So assuming it's genuine, I'm also assuming they came out of a phenomenally trashed bike.
Posted : 31/01/2012 11:54 pm
If that's aimed at me, NW, definitely no. Earlier today I changed out a pair of pads that have had several years' neglect. Back brake: mostly used on long descents, and I haven't ridden big climbs for yonks. There's surface rust and traces of green paint on the old pads. The friction stuff is still stuck on there, except where it wore away to the backing and made the brake squeal. They've not been touched otherwise since I fitted them. It's the benign neglect theory of maintenance.
Like you I wonder what state the OP's bike was in, and equally what metal, plating and bonding went into the pads.
Posted : 01/02/2012 3:03 pm
I'll bite. Check my picture. That is a "trashed bike" ridden in winter filth then mostly left in a shed for 9 months before being dealt with. I'd cleaned the parts I thought would rust but didn't think about the pads. Nothing wrong with the OEM pads before I ignored them. Most certainly something wrong afterwards.
Posted : 01/02/2012 3:27 pm
Having laughed at this thread originally, same happened to me, the back brake started sticking and squealing and then pulled to the bars (made me go faster anyway). Pad surface had come off.
When I got home I had a look at the other pad, and the material was completely loose and only held in by the love of jesus.
Pads were bought in 2011, ridden in spring, then taken off whilst i had kevlars on over summer, fitted them again for winter. Bike is kept in my flat and dries quickly. Very surprised at the amount of rust on them but I guess they get hot and wet a lot, not sure that the water should be getting in behind the pad material so much though?
Guess the moral of the story is either don't use pads for more than a few months, or don't use superstar pads, not sure which!
Posted : 08/03/2012 8:26 pm
Couple of rides: this is the pair of pads. Two sets did this, one set did four months. Who knows. And the owner was a chump who I refuse to give money to anymore - better people to give money too, even if it is a few pence more.
Posted : 08/03/2012 8:31 pm
I'm sure water shouldn't be able to get between the pad and backing plate like this.
Posted : 08/03/2012 11:49 pm
Use them all the time with no issues. Bike almost never cleaned. Maybe I am lucky...
Posted : 09/03/2012 12:09 am
lol... 🙂
Posted : 09/03/2012 12:18 am
So in the interest of "science / research" when did you guys with failures buy your pads? I wonder if its date /batch related?
Personally - I've not had any problems - I'm working through the 4x deals I got in late 2010 ish.
Posted : 09/03/2012 12:20 am
the web site says same stuff at half the price, he lies...
Posted : 09/03/2012 12:23 am
Page 2 / 2
