Does anyone know if these cheap things work?
http://www.ebay.co.uk/itm/SunRace-11T-COG-Cassette-fits-Shimano-SRAM-and-Sun-Race-FL03E-/261522553887?pt=UK_sportsleisure_cycling_bikeparts_SR&hash=item3ce3f57c1f
The aim is to replace the 12t on my 9 speed deore cassette with 11t thereby making an 11-36 cassette.
cheekybump. it's only 4 quid I guess so not the end of the world if it doesn't. undoing the lock ring will be more hassle!
Rose Bikes sell individual Shimano cogs
weird, I don't see them on the website
Sunrace make a 9 speed 11-36 casette .
sideshow - Member
XT 11 tooth here
9-speed here
Search for "11-tooth"
Will it still shift properly then if you swap 12 for 11t?
Also worth mentioning that you'll need an 11t compatible lockring, a 12t usually fouls the chain as it's a bigger diameter.
I did the switch tonight to put an 11t on the road bike using an old mtb cassette. Worked fine but I needed to use the donor lockring and the 13T since the design was slightly different, so my advice would be to find a donor cassette instead of buying the 11T on its own.
Thanks, sounds like more faff than its worth then, will just get a sunrace 11-36 cassette next time!
