Stupid BB question
[Closed] Stupid BB question
[#11141127]
I've just bought an X01 crankset which is Bb30 spindle sized.
Anyone out there using these and can recommend a threaded BB?
I've seen a few like nukeproof and the praxis one but they seem to have smaller diameter bearings on one side.
Stupid question I know but never had this BB type.
I've seen the Rotor one which looks good at just over £30 and I know about the hope one, just wondered how others have got on?
Cheers Rob
Posted : 14/04/2020 7:49 pm
I've not used that combination but wheels manufacturing have solutions for most bb/crank combos. This one might work?
https://wheelsmfg.com/bottom-brackets/threaded-bb/threaded-to-30mm-abec-3-bb-black.html
Posted : 14/04/2020 9:54 pm
You're always going to be compromised slightly as the larger diameter BB30 axle means you need smaller bearings to fit into the BSA threaded style bottom brancket
Posted : 14/04/2020 10:02 pm
BSA30 is the generally adopted terminology. Wheels Manufacturing are good - the use bigger bearings than for example, a Raceface plus they have an extra external seal.
Posted : 15/04/2020 8:12 am
you sure its not DUB?
i made the mistake of grabbing a BB30 crank thinking it could be used in a BSA frame
i gave up looking for a solution as a standard BSA frame has the bearings sitting outside the frame BB area, and press fit BB generally sits flush? so the crank spindle wouldn't be long enough
Posted : 15/04/2020 9:57 am
It hasn't arrived yet but advertised as BB30
I think it's either down to a hope Bb30 or I've found a Rotor Bb30 for threaded bbs
Posted : 15/04/2020 9:59 am
 PJay
If it's [url= https://www.sram.com/en/sram/models/fc-x0-1-b1 ]this one[/url] SRAM are listing it as BB30A if that matters, the Boost version does seem to be DUB.
Posted : 15/04/2020 10:11 am
