Stuck Shock Bush He...
[Closed] Stuck Shock Bush Help!! - Paging Vortexracing
[#369198]
Changing the shock bush but the old brass bush in the eyelet of the shock is TOTALLY welded in. No amount of persuasion is budging it. ANy solution ? Thought maybe cutting away a small section with a hack saw blade and then maybe pushing ? It should cut easy as its brass.
Alternatively, Vortex if you read this any chance I can borrow you bushing tool ?
Posted : 07/03/2009 12:33 pm
YHM
Posted : 07/03/2009 12:40 pm
Heat is the key - and you can easily make up a press with bolts and spacers. Sockets make good spacers
Posted : 07/03/2009 1:25 pm
cut the brass at the top and bottom then **** it out with a socket
Posted : 07/03/2009 1:38 pm
I hope no one suggests you are a fumble-fingered numpty boy 🙁
Posted : 07/03/2009 2:07 pm
They would be correct Simon.
Cheers Dave. Probably a better stocked garage than most LBS workshops. Your a star mate.
Posted : 07/03/2009 2:19 pm
No problem.
Oh and say thanks to your wife from me 🙂
Posted : 07/03/2009 2:24 pm
No problem mate... I'll pick her up next week.
Posted : 07/03/2009 2:25 pm
