Stuck Cassette
[Closed] Stuck Cassette
[#1620051]
so, tried to change the cassette on the commuter bike on the weekend and its stuck.
any ideas on how to get it off?
Posted : 18/05/2010 1:30 pm
Spray a bit of wd-40 into the splined grooves, leave to soak in, tap off carefully from behind with long screw driver & hammer?
Posted : 18/05/2010 1:35 pm
is it a hope pro 2 hub? I had a sram pg950 cassette stuck on a hope pro 2.
Posted : 18/05/2010 1:36 pm
2 chain whips, one going one way one going the other to pull it off of the cassette splines which it's possibly cut into
Posted : 18/05/2010 1:37 pm
Hope Pro II? (seems slightly excessive for a commute but you never know)
Either way try tapping the cassette anticlockwise with a mallet, to knock it out of any gouges it's made on the freehub body. Alternatively get a piece of wood and smack it from behind (through the spokes)
Posted : 18/05/2010 1:38 pm
As 29er said, sometimes the casette digs into the splines, you'll need to contra-rotate it slightly wrt the freewheel body to get it off. A mallet worked for my silly road wheels on which the problem occurred.
Posted : 18/05/2010 2:04 pm
