Stripped thread on ...
[Closed] Stripped thread on stem....fixable or stuffed?
As title i was over eager with the hex keys and stripped one of the stem bolts that holds it to the steerer. Is it fixable or busted now?
Posted : 22/04/2010 11:08 am
If you have a drill and hellicoil it wont be a problem.
Drill old threads out then slide a coil in and tighten
Most engineering website will sell them
Posted : 22/04/2010 11:11 am
Which thread has gone - the bolt or the stem? Probably the stem as its softer. Easy fix with a helicoil. should be £5-10 to do
Simpler might be to drill and tap with next size up if there is enough meat around the holes and you can get a bolt.
Posted : 22/04/2010 11:24 am
Or drill out - then on the opposite side drill a countersunk larger diam hole and inset a washer and nut? If you haven't got a larger diam bolt?
Posted : 22/04/2010 11:31 am
Posted : 22/04/2010 4:55 pm
