Strap on bottle cag...
[Closed] Strap on bottle cages, side entry ones- options?
[#10590231]
I'm looking at my frame thinking I can get a bigger bottle on using a strap on side entry cage, but needs to be low profile mounting, there is an SKS not side one but seems to sit quite far away from the frame.
Posted : 19/04/2019 9:44 pm
You can get strap on cage mount bosses and fit whatever bottle cage takes your fancy.
Posted : 19/04/2019 11:46 pm
I'm wondering if a side-entry cage might just push the strap-mounts round when you try to insert a bottle.  Will prob still go in but you might end up repositioning and that'd piss me of after a while
Posted : 20/04/2019 12:24 am
Sounds like the OP wants something that holds the bottle as close to the tube as possible, which strap on mounts with a standard cage bolted to it won't achieve.
Posted : 20/04/2019 12:28 am
Kelvin, yes that. Its currently zip tied to the shock mount.
Posted : 20/04/2019 8:47 am
Could something like the Fabric cageless bottle or Fidlock offer a solution?
Posted : 20/04/2019 9:20 am
No bottle mounts on mine either I went with 'r3pro' 3d printed mount. works great even mounted under my downtube.
Posted : 20/04/2019 9:24 pm
Does that fit any bike? And does the tape stay stuck? Looks useful.
Posted : 21/04/2019 12:07 am
MT ZOOM do a good one, but I think you'll need bolt holes: https://mtzoom.com/collections/cages-and-bottles/products/dual-sided-side-pull-cage
Posted : 21/04/2019 11:54 am
So far so good.
Posted : 21/04/2019 1:16 pm
