Straight steerer 29...
[Closed] Straight steerer 29er rigid fork - unicorn poop?
[#8300184]
Do they exist? My 26er frame is straight head tube, and I have a hankering for building a 69er frankenbike. Does the fork in the title exist? Or am I hunting for unicorn poop?
Posted : 22/01/2017 9:14 pm
Planet X have a couple of options. I'm sure others are available.
http://www.planetx.co.uk/i/q/FOMK35CF/mkm-35-rigid-carbon-mtb-fork
http://www.planetx.co.uk/i/q/FOOOSCF4709/on-one-monocoque-straight-steerer-carbon-fork
Posted : 22/01/2017 9:23 pm
Singular Swift fork?
Posted : 22/01/2017 9:24 pm
Salsa are your friend here. Chromoto or Firestarter, take your pick.
Posted : 22/01/2017 9:25 pm
Planet X as above, or try exotic: http://www.carboncycles.cc/?p=197 - been using both for years with no issues 🙂
Posted : 22/01/2017 9:26 pm
You [i]might[/i] be able to get a 29er wheel and tyre into a 26" rigid fork, but I don't know how much mud clearance you'd have.
Posted : 22/01/2017 9:27 pm
You might be able to get a 29er wheel and tyre into a 26" rigid fork, but I don't know how much mud clearance you'd have.
This much (with those exotic forks): https://www.flickr.com/photos/37065594@N06/27181275784/in/dateposted-public/ (apologies for the rest of the pic!)
Posted : 22/01/2017 9:34 pm
Stooge fork? Lots of offset so on a 69er it'll be 'interesting'
Posted : 22/01/2017 9:35 pm
You'd be better off wth a 26" fork unless the frame is designed around a long suspension fork, as the 29" wheel will lift the front end by 31.5mm anyway.
Posted : 22/01/2017 9:36 pm
This is what i used to do, it does work if your tyre is in the low 2s and not too tall. It also means that the geometry isn't changed too much.
I ended up buying a Salsa Chromoto which worked really well, it has a 20mm thru axle and is for sale if you are interested.
Ps if i was doing it again I'd prob get a 650b wheel and stick a bigger tyre in there..
Posted : 22/01/2017 9:37 pm
Plenty room in a carbon 26" fork.
Posted : 22/01/2017 9:39 pm
Pace / surly and Genesis all have/had steel straight steerer 29r forks so should be plenty to search for
Posted : 22/01/2017 9:42 pm
Genesis one was 26" length (445mm) as the frame was build around a non-suspension fork. It'd be ideal if you can find one.
Posted : 22/01/2017 9:50 pm
Niner do a nice steel fork. Pricey though, but rides lovely, I've ran a few Frankenbikes, ran an Inbred as a 69er once. It wasn't great. Geometry all over the place. Best combo was a 29er rigid with 26" wheel. Was spot on like that.
[url= https://c1.staticflickr.com/7/6097/6276734478_b45153dc33_b.jp g" target="_blank">https://c1.staticflickr.com/7/6097/6276734478_b45153dc33_b.jp g"/> [/img][/url][url= https://flic.kr/p/ayDUtY ]IMAG0257[/url] by [url= https://www.flickr.com/photos/takisawa2/ ]pten2106[/url], on Flickr
Posted : 22/01/2017 9:54 pm
Was that an 800mm seat post?!?!
Posted : 22/01/2017 10:34 pm
Ison do a nice one for just over a hundred quid. 465mm ATC so maybe a little long for what you want?
[url= http://www.ison-distribution.com/english/product.php?part=FKITXT46K ]Ison 29er fork[/url]
Posted : 22/01/2017 11:12 pm
Try the 29r wheel in a 26r fork if you have one.
In contrast to Takisawa I found it worked really well on my 456 with a 29*2.1 in there(although I'm back on 140mm 26r forks at the moment as the rigid fork is in another bike) but then that's a bike designed to be better with a longer fork in (I tried the same rigid fork and 26" wheel and it was way too nervy).
I reckon any taller fork with a 29r wheel and it would be a wandery mess.
Posted : 22/01/2017 11:17 pm
The Genesis rigid fork that I tried was brutally stiff and uncompliant - I wouldn't reccommend it.
The best fork, in my opinion, would be a Singular Hummingbird/Gryphon fork - 445mm a/c and 55mm of offset.
Finding one might not be so easy now though. The Stooge fork is also 55mm offset, I think but I don't know the a/c dimension.
i don't know about the greater offset making the handling "interesting"?? - it's what plays a big part in making the Hummingbird (and presumably the Stooge) such great handling bikes.
I'm positively evangelical about the Hummingbird's handling.......
Posted : 23/01/2017 9:34 am
I've been impressed with the my Mosso rigid fork, it's taken some decents hits and is reasonably light at 800g. They're only £50 off eBay, plenty of clearance for a 29" tyre, straight steerer, QR axle only though I think.
Posted : 23/01/2017 10:26 am
Surly Karate Monkey - http://surlybikes.com/parts/all/karate_monkey_fork
shermer75 - Member
Tell me more about these please
Posted : 23/01/2017 10:31 am
1st Gen iO fork? 28.6mm untapered blades and was a bit direct : ) Fortitude fork was 445mm and had tapered + butted blades.
Posted : 23/01/2017 10:36 am
plenty of room for a 29x2.4 in a 440mm 26" fork, front end sits about the same height as with a sagged 120-130mm sus fork
[URL= http://i626.photobucket.com/albums/tt348/shawnmcfarlane/IMG_1208_zpsz8jvguro.jp g" target="_blank">http://i626.photobucket.com/albums/tt348/shawnmcfarlane/IMG_1208_zpsz8jvguro.jp g"/> [/IMG][/URL]
Posted : 23/01/2017 11:44 am
Exotic's round tube forks are great tbh, I'd probably go straight there if I wanted a rigid today.
Posted : 23/01/2017 11:53 am
