if i have an SLX 2-ring front mech, do i need a 2er shifter or does it still work with a conventional 3speed shifter?
fanks.
Posted : 02/09/2012 3:14 pm
Works fine with a 3 speed shifter
Posted : 02/09/2012 3:16 pm
It's the mech that has the stops not the shifter.
Posted : 02/09/2012 3:19 pm
Just set the limit screw accordingly!
It will work fine with a 3x shifter, just adjust your hi/loscrews, to stop the extra setting pushing the chain off to where the 3rd ring would be.
A 3x shifter would have 2 shifts in each direction (2 up 2 down) so when you use it on a double, there will be a "dead" shift at one end.
Posted : 02/09/2012 3:20 pm
ok, cushty....
currently have a 3spd mech and have turned the screws on it and it works fine with a 3spd shifter. just wondered if the pull ratio was different for a 2spd mech.
cheers!
Posted : 02/09/2012 3:26 pm
