Still suffering fro...
[Closed] Still suffering from severe bout of chainslap?
Have a lizard skin chainstay protector but still getting really bad chainslap? Only seems to have started after I fixed a puncture any ideas?
Posted : 17/04/2014 8:32 am
Singlespeed
HTH
Posted : 17/04/2014 8:34 am
Clutch mech
Posted : 17/04/2014 8:36 am
Erm..
Posted : 17/04/2014 9:28 am
Have you got a clutch mech? Have you turned it off when taking the wheel out? You need to turn it back on.
Posted : 17/04/2014 9:33 am
Off-hand just because you removed the back wheel, there should be no obvious reason (I can think of) why that would cause chainslap. Unless you've a clutch rear mech, and have switched off the clutch mechanism, to remove the rear wheel (as required) and not switched it back on afterwards
See the Shimano clutch mech (sram's are different), notice the grey lever in the "on" position above the top jockey wheel, it has an off position 90 degrees (or there abouts) clockwise
Posted : 17/04/2014 9:39 am
if its a non-clutch mech then get a clutch mech or a blackspire stinger to take up the chain slack
Posted : 17/04/2014 9:41 am
balance-bike
Posted : 17/04/2014 9:50 am
Thanks for replies, Ive got a boardman fs 2014 so its the..
SRAM X7 2x10 trigger gear shifters
SRAM X7 TYPE 2 10 speed clutch rear derailleur
Another thing, when changing into high gear the chain comes completely off the rear bit and jams inbetween the plastic bit.
(still a newb)
cheers lads
Posted : 18/04/2014 9:00 pm
Hmm, clutch mech then but not with a switch. Is the wheel definitely in properly? Try slackening the qr off, and pushing down on the bike to compress the suspension a touch then re-tighten. You didn't by any chance use the lock button on the mech to hold the arm forward then forget to turn it off did you?
Posted : 18/04/2014 10:13 pm
Ive got a boardman ffs
ftfy
Posted : 18/04/2014 10:43 pm
Chain too long?
Posted : 19/04/2014 7:16 am
It sounds like in changing your puncture, you have something misaligned. It could be just a simple cable out its stop on the frame or mech, wheel wonky in the frame, chain not on the mech jockey wheel or similar. It could also be that the mech is now misaligned somewhat more permanently by being bent itself, bent mech hanger or broken spring. Go and be really fussy in looking it over, and follow a couple of you tube vids on how to sort you rear mech /gears out.
Posted : 19/04/2014 7:32 am
Also - if you can, take some photos of frame from the top, of the back of the bike. Showing the cassette, the chainstays, the QR and the mech.
Post them up on here, and we'll be able to take a look.
Posted : 19/04/2014 7:35 am
Nice one for the help lads, I could look for hours on end but when you haven't got much a clue its a pain in the arse! anyway here are some pics.. so do you think its worth buying one of these chain tensioners or shouldn't I need one?
also whats bad about boardman bikes. it was my first purchase and I thought for £900 it was a bargain?
thanks for the help
Posted : 19/04/2014 2:17 pm
I'd say judging by the first pic you mech hanger may be slightly bent, but that could just be the angle and light
The screws marked H and L are the screws that limit the mechs movement range (aptly named limit screws) correctly adjusted these will stop you shifting off the cassette at the top and bottom
Nothing particularly wrong with Boardman,it's more the place that sells them
For the money seems alright though?
It does have Avid brakes fitted which are a PITA to bleed, and you'd be better of replacing them with a set of Deores when they start to need a service IMO
Posted : 19/04/2014 2:59 pm
With a clutch type mech you shouldn't need a chain tensioner
The limiter screws ("H" and "L") need to be adjusted to stop the bike going off the "high" gears into the plastic guard (the big gears on the rear are actually the low gears & so the L screw is what needs to be adjusted). See this [url=
(though I'd say you can do it without removing the gear cable)
None of what you've said suggest to me the mech hanger is bent, and the photo can be misleading (I could be wrong).
I'd suggest going and talking to the mechanic in Halford branch you bought it from, to ask them to setup the rear mech inner limit properly and ask about the sudden increase of chainslap (maybe the mech has taken a bash and isn't performing correctly)
Or if you tell us your general location, maybe some-one can recommend a reputable shop to ask at...
Nowt wrong with Boardman bikes, only bike snobs and forum 'funny men' would suggest otherwise.
Posted : 19/04/2014 3:22 pm
Sorry, it was a flippant remark posted late at night, unnecessary and not even funny.
Posted : 19/04/2014 4:24 pm
not even funny
I chuckled - was clearly a joke so don't let yourself be browbeaten over it
Posted : 19/04/2014 4:56 pm
They don't look straight actually,,
Posted : 19/04/2014 6:41 pm
