Stiffest normal QR ...
[Closed] Stiffest normal QR fork?
[#2264174]
Looking at getting a new fork for the mmmbop, to replace my MX Comps. I have a dynamo hub so am limited to standard QR forks, but I can fit any size headtube.
I have a lyrik with 20mm maxle on the remedy, and I know how much stiffer that feels, so with this limitation what do people feel is the best you can get on QR?
Thanking ya
Posted : 08/12/2010 12:35 pm
I am very pleased with my Maguras plenty stiff enough for me and just a brilliant fork all round.
Posted : 08/12/2010 12:39 pm
Bomber 44s maybe?
I know if it was me I'd be looking seriously at a new front wheel as well if stiffness is a major factor for you.
Posted : 08/12/2010 12:40 pm
Probably one of the DT Swiss forks. Their lowers are hugely stiff for QR forks.
Posted : 08/12/2010 12:51 pm
wot matthew h said. I had some pace RC41s and they were SO much stiffer than the revs I'm riding now
Posted : 08/12/2010 12:56 pm
Anything from Magura with the double arch lowers.
Magura’s distinctive low-slung double arch brace design immediately distinguishes the Odur in terms of steering control. It locks down steering for outstanding on-trail accuracy that’ll shame anything this side of a bolt-through fork.
http://www.bikeradar.com/gear/category/components/forks-suspension/product/odur-09-31621
Posted : 08/12/2010 1:07 pm
Hey ta, I hadn't thought of DT Swiss stuff, will check them out.
The Magura looks really nice but I remember trying a Thor a mate had...wow divetastic! Maybe he had set it up wrong.
As for wheel, hadn't thought of that either. I have a XM719 rim currently, and the dynamo hub has really wide flanges, so probably need to upgrade the fork first.
I had the MX comps apart a while ago and was *shocked* by how flexy the lowers are on their own. Magnesium I think. Almost bent the arch without trying.
Posted : 08/12/2010 1:18 pm
I've only had one Magura but yeah, it is tricky to set up to be soft enough to work properly without diving. Stiff though!
Posted : 08/12/2010 1:23 pm
I'd say Jnr T but I guess thats not really what you're after!
Posted : 08/12/2010 1:31 pm
Maguras here too!!
Posted : 08/12/2010 1:34 pm
Most lowers will flex if there is no hub in there. That goes for bolt-throughs too
Posted : 08/12/2010 1:35 pm
I always struggle to proceed without a wheel in place though. In spite of the massive power that I generate.
DT Swiss......
Posted : 08/12/2010 1:40 pm
I wheelie through in that scenario, but I was talking about taking them off the stanchions 🙂
The Magura Laurin FCR looks perfect! But thy don't make it anymore.
Only thing over 100mm now is the Thor, and that's 20mm only...d'oh!
Posted : 08/12/2010 1:52 pm
My maggies are the 120mm Marathons which actually bottom out at 130mm and are still available.
As for dive I think they are fine I'm 16 stone and when set up right they work well, not divey but they are very linear, coming from Fox forks they did feel less progressive but then again they gave full travel. They are seriously light too.
Please you see
http://cgi.ebay.co.uk/Magura-MD120M-Mountian-Bike-Suspension-Forks-/160510280819?pt=UK_sportsleisure_cycling_bikeparts_SR&hash=item255f288473
Posted : 08/12/2010 2:34 pm
maguras here too, the do seem to dive below a certain pressure, then get too stiff, the sweet spot is tiny! Once youve got it though thyere great, PeterPoddy took some pics at the weekend and thye dont look too dive tastic, if anything they look a bit too extended!
Posted : 08/12/2010 10:00 pm
Maguras for me too! Not noticed a diving problem on my 07 Menja 100s. I'm sure I saw them rated as the stiffest around when I was researching them - I bought them cos they were dirt cheap!
My other bikes had a set of Maxle Boxxers and a set of X-Fusion Delta 8's with about 45mm stanchions and a 35 bolt in hub. I don't notice the Maguras flexing.
Posted : 08/12/2010 10:06 pm
ooOOoo are you using the dynamo off road and if so what light are you using? I have a dynamo hub but apart from the expensive Supernova E3 Triple I'm not aware of what else is avaliable that will be suitable for off road.
Posted : 08/12/2010 10:21 pm
avdave I have an IQ fly at the moment which is totally useless off road 🙂
I may try a home build at some point, but the next thing to go on will be this
Posted : 09/12/2010 11:57 am
Deffo the pace/DT swiss - piss all over my maguras (admittedly the older phaons).
Posted : 09/12/2010 2:01 pm
Thanks ooOOoo I guess I'll just have to wait until others enter the market. I only ride at night off road on the commute home in the winter and can get by with the old cateye halogen lights I have.
Posted : 09/12/2010 2:05 pm
Magura phaons don't have the dual arch design, so not a good comparison :-p
Posted : 09/12/2010 2:48 pm
There's also the edelux lights but they are not cheap either.
The IQ Fly is lovely but the beam is so narrow you can barely turn a corner. I was tempted to try this
And overlap the 2 beams, but another IQ fly is still about £70 🙁
http://translate.google.com/translate?js=n&prev=_t&hl=en&ie=UTF-8&layout=2&eotf=1&sl=de&tl=en&u=http%3A%2F%2Frudis-radladen.blogspot.com%2F2007_11_01_archive.html
Posted : 09/12/2010 2:49 pm
dunno why everyone thinks dt forks are so stiff? i know my older xmc130's werent particularly stiff at all for a qr fork..
Posted : 09/12/2010 4:50 pm
The old Pace RC40s (now DT Swiss somethingridiculouslyexpensive or other) were supposed to be extremely stiff considering their QR dropouts.
Mine weren't bad from memory, although the Pikes I replaced them with were in a whole different league.
Posted : 09/12/2010 4:59 pm
Pikes have a QR?
Posted : 09/12/2010 6:27 pm
We've got a pir of DT lowers in the shop that you can compare directly with a pair of Revelation lowers. Neither have internals fitted so it is only the lower leg assembly that you are comparing and the DTs are massively more stiff than the Revs. You can take the bottom of the Rev legs and easily pull them apart and twist the fork. I can barely move the DTs at all. The service intervals on the DTs also back this up.
That's why I claim the DTs are really stiff, I've tried to flex them.
Posted : 09/12/2010 6:33 pm
Pikes have a QR?
Erm, I was just illustrating a point...
Posted : 09/12/2010 7:08 pm
F-all is the difference from your mx vs most qr forks you will feel. Next.
Posted : 09/12/2010 8:28 pm
You ridden and compared all these forks then messiah?
Posted : 09/12/2010 11:25 pm
Fox F120 qr vs Reba maxle vs old bomber = F-all unless your forks are trollied or your some kind of bike god. I dislike qr because they come lose, not because they are less stiff that you can feel on the trail, marketing 101.
Lyrik is a beefy fork, nothing short of similar or 36mm will compare, imho.
Posted : 09/12/2010 11:45 pm
So all QR forks are created equal messiah? You seriously believe that there is no difference in stiffness between any QR forks? SID vs Pace/DT?
And I don't recall ever having a QR come loose if it was done up properly in the first place...
Posted : 10/12/2010 12:13 am
I've used RC41's on my BFe as well as a few different 20mm bolt-through forks (Talas, 55r's, Pikes) and can't say I found the RC41's noticeably flexier.
Posted : 10/12/2010 12:29 am
Thanks messiah - much more useful than your original answer 😀
FWIW I use hex-skewers with QR forks. *In theory* it could increase stiffness, because it's easier to do them up tighter, but it's also less likely to undo itself.
Posted : 10/12/2010 9:59 am
"I dislike qr because they come lose, not because they are less stiff that you can feel on the trail, marketing 101"
qr's shouldn't ever come loose unless it's a crap qr design or not done up properly, never had that problem in 20+yrs of riding. but all my bikes have bolted forks now because there definately is a performance advantage - not always that they feel hugely stiffer but that they bind less and work smoother. but imo, they do feel stiffer laterally, and taper steerers feel stiffer under braking. i hate having to change to new standards for no reason, but in this case i have done becuse they're that bit better. not worth paying for just for this alone, but if upgrading it's definately worth it.
as qr forks go, DT's feel stiffest. in fact as forks go in QR or 15mm, they're as solid feeling as they get.
Posted : 10/12/2010 7:53 pm
I run RC41 fighters, incredibly stiff.
Posted : 10/12/2010 8:39 pm
