Stiff SRAM x9 shift...
[Closed] Stiff SRAM x9 shifters
[#1976703]
Compared to shimano mine seem really stiff. Is there anything I can do to loosen them up?
Posted : 09/09/2010 11:06 pm
Chances are its the cables are really stiff not the shifter itself. Replaces the cables (both inner and outer) and see what they are like.
Posted : 09/09/2010 11:21 pm
all the cabling is pretty new, and isn't too twangy
Posted : 09/09/2010 11:23 pm
How stiff is really stiff? Compared to the shimanos are they twice as stiff or what?
Posted : 09/09/2010 11:30 pm
stiff enough that i've sprained a thumb shifting - at least twice as much resistance as the shimanos
Posted : 10/09/2010 12:38 am
Your cables are shitted up then.
Replace them with Shimano SP41 outer and a good inner.
Posted : 10/09/2010 1:30 am
It you're sure it's new cables then open it up and take a look. I had to do mine today on the trail because some grit must have got in there and was stopping it downshifting and making upshifts very stiff. Cleaned, a drop of lube and screw back together. It couldn't be easier.
Posted : 10/09/2010 3:34 pm
That doesn't sound right, something's stuck ia housing somewhere, or you've a break in the out causing it to compres and foul the cable.
x9s are a little firmer than Shimano, but more like 'crisp' than 'injury causing'.
Posted : 10/09/2010 4:10 pm
Thanks for the pointers so far.
I'll whip the covers off tonight. They are on a pretty much new bike which had the cables properly cut & fitted. Levers have always been stiff - I was hoping they would loosen up with use...
Posted : 10/09/2010 7:10 pm
