Hi,
I'm new to the world of hope hubs and I have a pro 2 rear hub and it seems rather sluggish on the freehub, so much so that when I spin the pedals in reverse the chain doesn't turn the hub backwards until the rear deraileur is pulled forward and there is actually some reverse tension on the chain.
I'concerned that A, it won't roll as fast downhill and B, when you wheel the bike around the pedals will turn because the free hub is acting more like a fixed hub.
Any thoughts? The hearings in the free hub seem smooth when I put my finger in and move them round....
Col
Have you had the free hub off and give it a good clean?
You probably need new bearings somewhere in the rear hub. Most likely in the freehub.
Is it new? Mine were like that when I got them but spin lovely now, if it's old it probably needs cleaning and stuff..
Mine was like that when new. I just took it apart and added a bit of grease to the seals, which helped. They take a bit of time to wear in.
Sounds to me like the freehub seal isn't seated in the grooves properly or is the wrong way round.
If you have dismantled the hub you may have re-assembled it with the spacer in the wrong position, the spacer prevents the free-hub tightening against the main hub body when you re-assemble and refit the cassette with the lock nut, recheck this before you ride out again as the chances are you will wreck the hub, the hope web site has exploded diagrams which show the correct sequence to reassemble.
^ This.
All to easy to get wrong. And don't fill the hub with grease or it won't work at all. A dab of light oil is all it needs (I use Bisley gun oil!).
Oh god, just spotted this...Fnarr-o-meter off the scale.... ๐
Most likely (as above), either you have missed off the spacer (potentially quite bad) or you have put the seal in the wrong way around or skew (not so bad, just annoying).
Youtube is good for hope stuff - the actual hopetech how-to's with the northern geezer with the big hair are good. Just don't let them fool you into thinking things just come apart with a gentle pull with your hands. This never, never happens with components that have actually been ridden on.
Mines the opposite, it just falls out. I was removing a hope end cap and the whole freehub just comes off.
Anyway to fix this?
