thought i'd try and place my spacers above my stem rather than below, to try and see if it helped lowering my ride position slightly.
will i get any issue not having a spacer before the stem and the top headset "bit".
not gone for a ride like t yet to know if it makes much difference.
not a problem.
No, the spacers are only there to make the bike fit you properly (as long as you put em in the right place anyway)
ive had to put a few spacers below my stem because the faceplate was fouling the top headset. its doing that because its a really short stem, 50mm i think.
Your power output may vary by 80 watts.
You're just trolling, Al...... 😡
It'd be 72.46 watts at the very most.
depends if it's carbon or alu
its actually a combination of that and how much your wheels weigh. that is the single most critical thing along with everything else.
I drilled some alu ones, but the results were negligible.
