Stans tubeless high...
[Closed] Stans tubeless highest pressure?
 RC
[#4225064]
Was looking at converting my rocket rons to tubeless.
Was told that you can't go higher than 40 psi, is that true?
Posted : 04/08/2012 10:17 am
Why would you want higher than 40psi?
The big advantage of tubeless is that you can run lower pressures.
Posted : 04/08/2012 11:08 am
Think Stans rims do have a max psi, can't remember what it is though. They also advise against using Schwalbe tyres tubeless.
Posted : 04/08/2012 8:01 pm
Maximum psi on Flow rims is 38 on a 2.1 tyre. I use NN without any problems
Posted : 04/08/2012 8:09 pm
Stans rims often have a little pressure chart on the sticker.
Max pressure changes with rim model
Posted : 04/08/2012 8:53 pm
