stans solution - Be...
[Closed] stans solution - Best before?
[#4438151]
does this stuff go off? just opened a fresh bottle this weekend, and after a good old shakeI still had a congealed plug of goop block up the nozzle straightaway. I was like you get when it 'balls' in your tyre after a while. Got me wondering whether there would be any useful particles left in the bottle...?
Posted : 08/10/2012 1:07 pm
Good question. I've certainly switched to buying little and often for this very reason.
Posted : 08/10/2012 1:26 pm
I also noticed the same thing at the weekend! The bottle isn't even that old - maybe 4 months or so
Posted : 08/10/2012 1:32 pm
well isn't the key ingredient still air drying liquid latex?
Would storing it under a vacuum help you avoid/reduce the issue?
But yeah leave it for long enough and of course some of it will dry out...
That's why I just use a basic latex/water homebrew, the branded stuff may work a bit better but making your own works out miles cheaper per Litre, if it drys out a bit earlier never mind, all the brand name stuff is pretty pricey for what it is... IMO.
Posted : 08/10/2012 2:03 pm
I have a bottle over a year old (first opened) that still seems fine (last used a couple of weeks ago, sealant came out as expected, in fact I'd have preferred to see a few more bigger bits of latex)
Posted : 08/10/2012 2:07 pm
if the nozzle blocked when you were trying to squirt the liquid out, then it is just doing the job it is suppose to do - seal holes. All the little rubber bits collect and bind together to seal the hole, just shake it again. It is good stuff 😉
Posted : 08/10/2012 3:19 pm
 JoeG
I've had the same bottle of Stan's for over a year, I think. There is only a little bit left, but it was fine a week ago when I topped off my tires. I've used Stan's for many years, and never had an issue with it drying out in the bottle, which is normally kept in the house.
Posted : 08/10/2012 7:04 pm
Lasts for years...
Posted : 08/10/2012 7:12 pm
