Stans flow ex or ma...
[Closed] Stans flow ex or mavic 521?
[#4817312]
Looking at getting some pro2 built up on either of the following rims...
Stans flow ex or mavic 521's
both priced the same but just wnated to get some veiws on which rim would be best.
Going on a stumpy full susser and will be used for all round riding fitted with largish 2.3 tyres.
cheers
Steve
Posted : 30/01/2013 10:20 pm
Anyone?
Posted : 30/01/2013 10:56 pm
Stans are toobless ready, not sure mavics are.
I've got ztr's on my FS running a minion 2.35 up front as it seems fine to me.
[url= http://singletrackworld.com/forum/topic/hope-pro-ii-what-rims ]Here's a previous tread on the very same topic[/url]
Posted : 30/01/2013 11:04 pm
Doh cheers for that, I did a search but nowt came up?
Posted : 30/01/2013 11:08 pm
 mboy
For the same price, get the Flow's. They're lighter and easy(er) to run tubeless on.
The 521's are good rims though, I run them on my bike (but I built my own wheels and 521's were 1/2 the price of Flows to me) and have done for some time. They're tough, reliable, give the tyre a good profile and they're not ridiculously heavy.
No problem.
The forum search is poo, but googling always brings up a loads of STW threads.
Hope it helps 😀
Posted : 30/01/2013 11:11 pm
I've not ridden the mavics but I have two sets of flows and rate them highly, they have stayed true despite my best efforts and I like the extra width that gives the tyre a slightly square profile compared to my old dt rims. And tubeless is very easy too.
Posted : 30/01/2013 11:35 pm
Get some 721s they are the best rims I have ever used. I am a proper wheel breaker and have had my Pro 2 and 721 for 4 years and they are still fine. To give my suggestion a sense of perspective I had some DT Swiss that lasted a matter of hours. Seriously I killed them on their first ride, it wasn't anything rough just my local loop. That was an expensive ride.
Posted : 31/01/2013 12:11 am
Just to confuse a little I'm proper impressed with the stans arch
Have them on my enduro but only trail centre use so far and seem nice and tough
Posted : 31/01/2013 12:14 am
They are both excellent. Also both right on the strong end of what a Stumpy's likely to make use of (721s are great too but downhill rims on a Stumpy doesn't make any sense to me)
Not being funny but what sort of all round riding is your all round riding?
Posted : 31/01/2013 1:21 am
721s are no more of a DH rim than 521s. OK so they are a few gramms heavier but that's because they are using denser, stronger metal and they can be used with v brakes.
I have 321s (due to lack of money) on my BFe I dont see why you wouldn't stick those or 721s on a stumpy. In fact I am thinking about replacing my Enduro with a Stumpy and that will be running 721s and 1x10.
Posted : 31/01/2013 11:46 am
Northwind......
Everything from riding to work to trail centres and also A week a year in cyprus up the troodos!
Posted : 31/01/2013 2:37 pm
If I was you- no heftier than Flows but Arch Ex would probably make more sense. Can't judge your riding really but Crests are pretty durable too but you lose a bit of safety margin.
Flow definitely a better option than a 521 though.
Posted : 31/01/2013 2:44 pm
Im 16 stone though if that makes a difference?
Posted : 31/01/2013 2:45 pm
Got some 521s with db spokes on 20mm XT hubs from Merlin in May 2011 they've been absolutely rock-solid and feel great - much more direct than a similar build I have using XM719s. There's a moment from slow speeds when the inertia is noticeable but otherwise they've been proper fit-and-forget.
Wouldn't hesitate to get another set
Posted : 31/01/2013 3:15 pm
Flows all the way and the new EX are ust ready, no need for rim tape.
Chris
Posted : 31/01/2013 3:25 pm
Chris_db do you mean no need for rubber rim tape or absolutely no tape, not even the yellow stuff?
Posted : 31/01/2013 3:41 pm
Mikey, they just need some tape to seal the spoke holes. 25mm gorilla tap efrom screwfix best, packing tape Craig gave me works but peeled off after a while.
Posted : 01/02/2013 11:17 am
Can't vouch for the stans, but my front wheel is a pro 2 with DT spokes on a 521 and my rear is a hope bulb, DT's on a 321. I'm 16 stone and ride a fair bit of DH type stuff on my five. The mavics seem pretty bomb proof to. Even if they are a bit heavier than the stand. Spose it depends how much you're bothered about weight though.
Posted : 01/02/2013 11:27 am
some right crap typed on here, no a big surprise really, 'tis tinternet afterall 🙄
Why would DH rims not make sense on a 6" travel bike? What about a hardtail?
721s are both stiffer and stronger than 521s, and both are stiffer than Flows
weirdly everyone seems to need bolt thru wheels these days but don't seem to care about rim stiffness!
Fashion?
hmmm... 😕
Posted : 01/02/2013 11:40 am
you ran off to Google to find an Alu 4x frame that is heavier? Well done! Doesn't alter the FACT many others are lighter.
No, I ran off to google to find some DJ frame weights. Could you link me to some DJ/4X frames which are lighter? I'd like to see some facts rather than opinions.
One doesn't like to raise the spectre of hypocrisy, but...
Posted : 01/02/2013 11:49 am
ho ho ho.. really?
I happen to own two which are lighter, how do I know this? I weighed them, I don't need to run off to google to "prove" my factual experience!
you carry on believing everyhing you find there though Chief 😉
Posted : 01/02/2013 11:57 am
I'm merely pointing out that the omniscient attitude of one such as yourself makes you sound like a **** and either fails to provide any useful information for anyone or puts the reader's back up so that they ignore your big-hitter attitude laden advice, even if it's good advice or information. Indeed this example just sounds like posturing with no actual content, so much as I'd like to believe you, many wouldn't.
Therefore you may as well just say nothing at all and stay quietly sitting on your high horse admiring the view of us distant plebs from your ivory tower. Say hello to GW if he's riding pillion with you.
Posted : 01/02/2013 12:06 pm
[b]fails to provide any useful information[/b]
oh, teh ironi...
C even BA..
Posted : 01/02/2013 12:15 pm
Been running Flow EX for about 6 months, tyres go on easy (UST RQ & UST NN), easy to inflate tubeless with just a track pump, not too heavy
, still run true, I'm happy with them
Posted : 01/02/2013 12:23 pm
oh, teh ironi...
C even BA..
QED!
Posted : 01/02/2013 12:27 pm
