ss/gear question
[Closed] ss/gear question
 taka
can you run ss kit on the back with a double+bash setup on the front? or will the chain always come off?
wouldnt be a true singlespeed but will help on the flat bits...?
Posted : 05/10/2009 9:30 pm
if its a well sprung tensioner, with enough throw, it [i]might[/i] work.
only one i can really think of that might work would be a rohloff one, which would be pricey.
Posted : 05/10/2009 9:32 pm
 taka
i was hoping it would be a cheap alternitive to gears so rohloff is outa the question..
Posted : 05/10/2009 9:33 pm
well fit a mech as a tensioner .... and a front mech for the changing at the front ... then a set of shifters and you might as well just have the cassette on too ...
Posted : 05/10/2009 9:34 pm
 taka
... ๐Ÿ™„
trail_rat - Member
LOL!
Posted : 05/10/2009 9:35 pm
well if you will ask a stupid question you will get a serious answer ..
Posted : 05/10/2009 9:36 pm
 taka
ill prove you wrong mr.rat ๐Ÿ˜ˆ
Posted : 05/10/2009 9:37 pm
the Alfine tensioner has a lot of spring, it has a pair of jockey wheels like a normal rear mech as some can and do run the alfine with a double on the front.
i can assure you you wont ..... its either a single speed or its gay* !
* owner of SS and super light super jey XC bike .....
Posted : 05/10/2009 9:39 pm
Hammershcmidtttt (sp?) perhaps, not exactly a budget solution though...
Yeah it's possible, most things are possible, but then why bother? you'll have 2 gears and neither will be the right one...
Posted : 05/10/2009 9:44 pm
 rob
Dinglespeed
2 cogs out back works
2 cogs at the front its a bit to much chain slack for most tensioners
Posted : 05/10/2009 10:01 pm
 ton
tom, why the **** would someone who lives in the hilliest area of one of the hilliest parts of the country want a ss. โ“
Posted : 05/10/2009 10:04 pm
twingle speed
Posted : 05/10/2009 10:28 pm
