SS road hubs
[Closed] SS road hubs
So I've managed to acquire another vintage road bike - a Dawes Jaguar. Now I've already got a fixed gear bike for general getting around, and I'd quite like something similar, but a bit easier to actually train on - being able to freewheel on corners would be nice in some instances.
But I'm having trouble finding a dedicated road SS hub. There's plenty of track hubs around, but nowt with a freewheel.
I'm pretty sure it needs the old 126mm spacing, as my Raleigh did, but being springy steel it'll easily bend in/out to 130/120mm.
Anyone seen anything?
Posted : 11/11/2014 7:27 pm
Can't you just screw a freewheel onto the fixed sprocket threads?
Posted : 11/11/2014 7:29 pm
 JoB
Goldtec do a SS/Fixed hub with replaceable axles so you can fit it to any spaced frame, you can screw a freewheel onto the fixed thread, as you can any fixed hub
Posted : 11/11/2014 7:34 pm
I've read a couple of threads that reckon putting a freewheel on a track hub would work, but not engage all the threads. So the consensus was that it'd be fine for smooth/light riders, but not for mashers for fear of stripping the thread.
I do have a bit of a tendency to mash, and I'm not too keen on stripping threads!
Posted : 11/11/2014 7:39 pm
 JoB
i've run a freewheel on a fixed hub on singlespeed CX bike for several years, it gets a bit of mashing, it's been fine
Posted : 11/11/2014 7:56 pm
loads of fixed/freewheel hubs out there.
I have a paul one thats super nice but pricey,
heres a surly one:
[url= http://www.winstanleysbikes.co.uk/product/31462/Surly_FixedFreewheel_Rear_Track_Hub_HUSURTDK?gclid=CjwKEAiAhIejBRCKm_fTxIWyyXcSJABXY0XYmm2qairTpHCPP0hA1EHWU3Q8W27sg6wWcr_qq5L_rRoCpKrw_wcB ]Clicky[/url]
Novatec, Miche, Halo all do versions also.
Some you can space out to 126mm with spacers and others you'll have to bend the frame down to 120mm.
Posted : 11/11/2014 8:05 pm
I have a Surly one, it's nice and comes in quite a few widths, quite pricy though. Charlie the Bikemonger has them I think.
Free/fixed combinations are often termed flip-flop hubs, you might have some success with searching for that.
Posted : 11/11/2014 8:10 pm
Hmmm, I wasn't really after a flip flop hub, purely for bike-tart reasons! I don't want unnecessary unused threads cluttering it up!
But it does seem like the most likely option at the moment.
Posted : 11/11/2014 8:17 pm
I have a White Industries ENO hub. It is a thing of great beauty. It has a fixed side and flipflops to have a screwon free wheel.
The really cool part is its an eccentric so u can use it on a frame with vertical dropouts.
i love it on my fixie
BMX hub like profile with a longer axle/female bolts??
Mind you, you don't get more tarty than Pauls or Phil Wood
Posted : 11/11/2014 8:29 pm
http://www.spacycles.co.uk/products.php?plid=m2b0s117p2852
Space out as appropriate.
Posted : 11/11/2014 9:20 pm
I'm just going to use the hubs that are on there at the moment I think. They're pretty standard fare Maillard, but I think with a couple of spacers a DX freewheel should fit.
Then I've always got the option of going 1/2x6 if needed.
Posted : 11/11/2014 10:03 pm
padkinson - Member
My take on that is that if it won't strip with a fixie cog, it's not going to strip with a freewheel.
Posted : 11/11/2014 11:20 pm
Just screw it on a Miche Primato Low Flange and be done. You won't be undoing it by back-pedaling and hence you don't need a lockring.
Better still, ride it fixed and you don't have to pretend with the absence of a flip flop ๐Ÿ˜‰
Posted : 11/11/2014 11:26 pm
Sightly off topic but apart from Surly does anyone make a nice disc compatible 135mm fixed hub?
Posted : 12/11/2014 11:10 am
