SS chainring recomm...
[Closed] SS chainring recommendations
Hi,
I need to replace a ramped 32t chainring on my 29er for an unramped SS specific. The cranks is 104 BCD compatible (4 holes).
I have heard a couple of bad things about the durability of the alloy Blackspire mono veloce. Are there alternatives out there?
Posted : 30/10/2009 3:34 pm
I have a Salsa one from Charlie the Bikemonger, very nice it is too.
Posted : 30/10/2009 3:37 pm
charliethebikemonger carries both Salsa and Surly chainrings. Thanks for the heads up. I should stop using CRC as my main shopping venues...
Posted : 30/10/2009 3:41 pm
BETD also do Goldtec ones which i use and seem to be very good.
Posted : 30/10/2009 4:17 pm
I've got one of the Stainless on-one chainrings - seems to be holding up
Posted : 30/10/2009 4:19 pm
Thorn also do a good range.
Posted : 30/10/2009 4:20 pm
I've not used one, but on-one do them too
Posted : 30/10/2009 4:21 pm
Charlie BM does FSA ones on his ebay shop as well - they're not listed on his own website though.
Posted : 30/10/2009 4:31 pm
I've used Surly and On-One. I think On-One look slightly nicer and are cheaper. Both seem to work the same.
Posted : 30/10/2009 5:03 pm
I somehow managed top bend my Surly ring, and was astonished at how easily it went out of shape.
The [url= http://www.on-one-shop.co.uk/acatalog/SS_Chainrings.html ]On-Ones[/url] Ive had seem to last ages. Highly recommended.
Posted : 30/10/2009 6:34 pm
The Surly ones do bend easily - but I've only done it when using it in a geared 2-ring set-up.
They last forever SS.
Posted : 30/10/2009 6:54 pm
+ 1 for goldtec, fab rings got them on both of my SS bikes
Posted : 30/10/2009 7:06 pm
The Surly ones work really well and last ages.
Posted : 30/10/2009 7:20 pm
I had a Blackspire Mono Veloce and it was alright. Mine seemed slightly eccentric to me, maybe it was defective, but I never quite got to the bottom of that.
Using a Thorn one at the moment and it's as brilliant as a chainring could be. Big teeth, long-lasting, smart-looking. Perfect.
Posted : 30/10/2009 7:29 pm
Loads of suggestions, thanks. What is the thickness of the On-one: 3/32 or 1/8?
Posted : 30/10/2009 8:37 pm
 gee
Renthal - now available from Ison Distribution.
GB
Posted : 30/10/2009 9:59 pm
 Keef
yup, goldtec here,been using them for a few years,like 'cause you can rotate 'em,and flip 'em over,so last like 8x as long.guess you can do this with others an all tho.......
Never bent one yet,and I've ridden over plenty of fallen trees.
Posted : 30/10/2009 10:59 pm
 jonb
I've had two chainrings from st john street cycles, the main importers of thorn but the ring is TA or similar own branded. One's been going for a few years, the other new. I like 'em.
Posted : 30/10/2009 11:17 pm
