I have an xo rear mech but the thread on the main pivot bolt is frankly shot,I have a new replacement screw.
My question to you is how do you take the one one out and put the new one in?
thanks
Bruce
(the screw in question is the one that secures the mech to its hanger.....
see if theres a circlip on the back, i think there's a groove in the bolt that it sits in that holds it in place
there'll be an exploded diagram on the SRAM websit
EDIT
page 20
i can't find one? if you can...i maybe just thick..
thanks
Bruce
Select X0 Rear Derailleur B-Bolt Kit Gold Part number :11.7515.036.020
thats the one.....so how do i get it out.?
looks like a spring clip on the back of the bolt
it is, iv'e done one and it's quite fiddly but doable,
khani how?....
could you explain bit by bit....
thanks
Bruce
on the back of the mech whrer the inside of the bolt pokes through behinde the the bit that the little angle adjustment screw is its a small ring which you pull/spread apart, i used a small elec screwdriver and some sharp point scissers, watch the clip dos'nt go poing
thanks khani...just struggling with the re-assembly of the pin...how can i open out the circlip?
thanks
Bruce
