sram x7 rear derail...
[Closed] sram x7 rear derailleur with XT cassette
[#4339303]
will a sram x7 rear derailleur work ok with a XT cassette
I cant find a 10speed sram 11-34 cassette
Posted : 07/09/2012 8:49 am
 cp
Yep fine. Assuming you're using the appropriate sram shifter, the rear mech will live quite happily with that cassette.
Posted : 07/09/2012 8:52 am
yep sram levers.
great cheers
do sram not do a 10sp 11-34
Posted : 07/09/2012 8:59 am
its probably because a 10sp 11-34 cassette is pointless.
Posted : 07/09/2012 9:10 am
how come?
Posted : 07/09/2012 9:15 am
 cp
the marketing men said so. for actual riding, it's great, particularly with a triple. But if it suits your riding, then go for it - as with all gear ratio stuff.
Posted : 07/09/2012 9:30 am
i thought the whole point of 10 speed was a bigger range cassette?
11-34 is a normal 9sp range. therefore you dont achieve any benefit from running this 10sp (other than maybe having a clutch mech - which you are not)
infact you probably end up with more of a maintenance liablity.
with the 'advancement' from 8-9speed they 'filled in' the jump in gear ratios in a 8sp cassete (or at least thats how it was sold) with 10 speed they've barely got a reason to jusify it. lord knows the reasoning behind 11 speed.
Posted : 07/09/2012 9:31 am
I's like a 34-34 ratio on my cx bike for the peaks. at present I'm running a 34/46- 11-28.
Posted : 07/09/2012 9:34 am
will I need a long cage? or medium?
which would be the most reliable?
Posted : 07/09/2012 9:53 am
 cp
you can use a medium cage on that set up - as you don't have the small inner ring up front which would neccesitate the long mech.
Posted : 07/09/2012 9:59 am
