SRAM X01 cage repla...
SRAM X01 cage replacements?
Going though my spares I found this again (off a friend, who used it as an excuse to go AXS), can you get Inner and outer cages at a reasonable price? Both were bent by a stick/mech incident and bashed into a reasonable shape trail side to get him home, so they will not be being bent back into shape again
For an older non T or AXS, 12 speed X01 speed mech. Finding lots of inner I'm pretty sure I found a complete 'upgrade' replacement set, when last I looked... that cost more than a new mech. My GX is looking decided tired, so thought I might try to get this one fixed.
Posted : 24/03/2026 11:04 am
Can you use the lower cage plates from the gx on the x01?
Posted : 24/03/2026 11:18 am
No idea but I would assume something that easy (& cheap) is not going to work... TBH I need to change the jockey wheel bearing on my GX, so will check.
Posted : 24/03/2026 11:28 am
These for AXS
https://ratiotechnology.com/product/sr52x-derailleur-cage/?v=7885444af42e
Whether you consider £90 reasonable is another matter
Posted : 24/03/2026 1:05 pm
Cheers for the option, but a quick google suggest that the same price as a new GX mech 🤣 (the X01 is well used)
I've now compared my GX with the X01 mech and the outerplate look exactly the same, the inner being different. Can I locate a GX one now...
Posted : 24/03/2026 1:13 pm
Looked on Tredz?
There's a GX here and a load of others listed below
Posted : 24/03/2026 2:35 pm
