SRAM X-9 PROBLEM. A...
[Closed] SRAM X-9 PROBLEM. Anyone else.......
[#2017782]
As some of you may have read last night I have been messing about with my new Bike ('10 Crush), to try and get the rear mech into top (high) gear. Having played with everything (and I mean everything), it transpired that I could simply push the mech into the final gear and therefore the spring was unable to pull it there and is simply not up to the job.
Another poster (mintimperial) identified the problem and I wondered if anyone else out there have had a similar issue ??
The bike shop I bought it from (internet purchase I am afraid) have offered to "fix" it if I send the mech back. This means I lose the use of the bike for at least a week so any thoughts on what I might do would be much appreciated. 😕
Posted : 23/09/2010 9:29 am
My 2010 crush sometimes struggles to drop into top. I played with it and it was ok for a while but still stuggles now and again. By the way what was the problem identified as.
Posted : 23/09/2010 9:43 am
A mate had to return two recently with failed rear springs - and they were brand new. My old one has done over 6000 miles with only replacement jockey wheels needed - maybe quality has slipped?
Posted : 23/09/2010 9:46 am
Grim - simply that the spring ain't strong enough to get it into top gear 🙁
Posted : 23/09/2010 10:15 am
 5lab
are you sure its not the limit screws or a bent rear mech hanger at fault?
Posted : 23/09/2010 10:16 am
 ojom
aye we have seen a couple through the shop like this albeit not from new. Usually with a few miles in em.
They simply decide to not want to spring.
Posted : 23/09/2010 10:18 am
A friend has a new X9 rear mech and on last weekends Ruthin marathon he had major issues. It turned out that the rivets that hold the parallelegram assembly together were too tight (compared to my one) and the spring couldn't over come it. I believe a few whacks with a centre punch to loosen them did the trick.
It actually fely 'tight' to move the mech by hand.
Posted : 23/09/2010 10:19 am
i had this, adjusted the B tension and it sort the problem - wind it in a lot
 dazh
I have the same problem, although with mine it's not the spring as I can't even push it into position. After much investigation I discovered that the limiting screw for bottom gear (largest sprocket) obstructs the mech body, preventing it from dropping down into top gear. I could resolve this by unscrewing the screw a bit so that it doesn't obstruct the mech but then this meant that the limit for bottom gear was wrong which resulted in the chain shifting past the largest sprocket and getting stuck between the cassette and spokes.
Seems to be a case of bad design if you ask me. Maybe it's fixable with more tweaking but since I never use top gear anyway I just ignore it.
Posted : 23/09/2010 10:23 am
Same here, b tension screw wound in sorted it same as Rootes1
Posted : 23/09/2010 10:32 am
same here - over adjusted the b tension and limit screw so it kind of shifts marginally beyond the small cog, all is good for mow, but when it gets muddy it stops working again 🙁
Posted : 23/09/2010 10:40 am
There is no b-tension adjustment on SRAM mechs surely?
Posted : 23/09/2010 10:44 am
They do. Why wouldn't they? They have no barrel/tension adjuster.
Posted : 23/09/2010 10:59 am
Oh yeah, so they do, that's very odd, I've never noticed it on mine!
Posted : 23/09/2010 11:02 am
I'm off home in a minute to give it a go !! 😯
Posted : 23/09/2010 11:06 am
njee20 - Member
Posted 12 minutes ago # Report-Post
is that cos you have xx? 😆
Posted : 23/09/2010 11:15 am
I tried the b-screw trick on mine: it didn't really help much, just slowed down the shifting across the rest of the cassette.
The only thing that has worked at all, as I said yesterday, is tons of WD40, wiggling for 1/2 an hour, and then (carefully) whacking the rivets with a centre-punch. But even that didn't fix it completely, it's still not quite right. I suspect that a winter of gritty Pennine mud would probably loosen things up enough, but after a couple of months putting up with it mine's going in the spares box as soon as the X.0 replacement arrives.
Posted : 23/09/2010 12:00 pm
 gamo
I had a 2010 x9 which wouldn't drop into the highest gear no matter what i tried,as the mech dropped it was fouling on the low adjustment screw!
Asked on here and a few suggested crap mechanic rather a fault but after returning it to the shop then Fishers i was given a replacement and told there was a manufacturing issue.New one set up perfectly then the three month old rh shifter stopped working!Been using sram gears for six years and build quality is definetly not what it was!
Posted : 23/09/2010 12:22 pm
Keep it well lubricated, especially the pivots, GT85 or similar. Most important during the wetter months. Kept mine shifting smoothly over the last 3 years.
Posted : 23/09/2010 1:00 pm
Known problem, SRAM are swapping them under warranty I believe (OH had hers replaced by the LBS a week or two back). On hers it was jamming in first gear, as though the spring wasn't strong enough to move the mech.
Posted : 23/09/2010 1:06 pm
Good to hear, as I was running out of ideas the other night whilst trying to get my 2010 X-9 to drop into highest gear. Replaced cable, cable outer, cleaned and lubed all the pivots, checked stops, chain and jockey wheels. Works fine in all gears until it tries to go to top, then it just moves very slowly on releasing the shifter.
Glad it's not just me then.
Posted : 23/09/2010 1:20 pm
