As the title says, i need one to replace the worn outer, but im struggling finding what i need. What other replacement chainrings could i use instead, its a 5 bolt pattern and 110 bcd. Suggestions ahoy please ๐ oh and maybe a linky or two thrown in the mix, cheers guys.
Come on, someone must know of replacement chain rings for this size. I did find the actual sram one, but it was mega expensive!!
Here's some 46t chainrings:
[url= http://www.sjscycles.co.uk/110-bcd-5-arm-dept498_pg1/#filterkey=displayoptions&displayoptions=teeth:46&page=1 ]SJS Cycles Chainring[/url]
I've put Shimano chainrings on SRAM cranks in the past and not had a problem.
Edit:
Ahh just noticed you said 11 -speed. Not sure any of them will do then.
well my mostly-Sram-Rival SuperX came with FSA cranks and chain rings (5-bolt 110bcd outer) so might be a starting point.
