Anyone know where I can get a spare part for my SRAM Ultimate Guide brakes ?
Seems I've lost the bolt that goes through the lever holding it on the clamp.
Still got the top part of the bolt, so it works. Just the bottom part has gone missing. But I cant seem to find any website in the UK that just sells parts.
I thought they were a standard MMX clamp? Got a photo?
Its the bolt that goes through the actual lever, one that has bearing in it.
Not the clamp to the bar bit.
This happened to mine too, I think I got the bearing and bolt set from AMazon
https://www.amazon.co.uk/d/Sports-Outdoors/SRAM-Bearing-Bearings-Hardware-11-5018-023-000/B00TTLHXXS
It's the part listed as 2 and 4 in this diagram
If I knew more about bolt lengths and threads chances are that I could have picked the bolts up infinitely cheaper.
That's the one. £23 from Amazon, ouch.
Drilled through the lever and fitted an m3x25mm with a washer and nyloc.. Stainless
Had been crashed and had sheared the bolts off and couldnt get the old ones out
How do I find out the type of threads on the bolt?
Stick a nut on it, one which you know the thread size of.
Assuming you have a pair of brakes can you not just take the other one to a decent ironmongers/fasteners and get them to match something up? Might have to settle for a cap head Allen bolt or screw as i'd imagine a Torx head is a lot less common.
