SRAM adaptor for Ya...
[Closed] SRAM adaptor for Yari's running 200mm discs
Methinks the Yari's are prepped for 160mm discs as standard? So I assume I need a +20mm or 200mm SRAM (only?) adaptor to run Level calipers with 200mm discs?
Wiggle have nothing, CC have a mix and [url= http://www.planetx.co.uk/i/q/BSSDBM/sram-disc-brake-mount-adaptor ]Planet X have what look like several options.[/url]
What's recommended?
Posted : 25/07/2017 10:54 am
the one that came on mine is marked +40mm from SRAM on Levels, using the equivalent Hope one as it's a standard post mount from what I see
Posted : 25/07/2017 10:57 am
Personally unless there's a good reason to use something else I'd use Shimano XTR adaptors, not the very cheapest but it's surprising how much excess metal is on a lot of the cheapies.
Yep, fork is 160PM standard so you need a regular 200PM adaptor (+40) for this application.
Posted : 25/07/2017 10:59 am
Cool.
CRC have [url= http://www.chainreactioncycles.com/shimano-mount-adaptor-front-post-to-post/rp-prod13747 ]these[/url] (no XTR available) and they'll do the trick. Ta
Posted : 25/07/2017 11:46 am
they are 203
these are 200s, and cheaper
http://www.chainreactioncycles.com/brand-x-disc-brake-adaptor-post-to-post/rp-prod138596
Posted : 25/07/2017 11:59 am
Ta Reggie, I've added those to the basket. Am hoping the Shimanos will fit, albeit might have to fudge a bit of adjustment. If not, the bolts might do the honours with the BrandX as they don't come with them.
Posted : 25/07/2017 2:09 pm
I've just fitted the brand x one to my bike, using Sram Guides. All good. Uses two pairs of regular bolts, rather than one pair of long bolts like the +20mm brackets.
The bracket doesn't come with bolts but that's not a problem for me as I have loads of spares.
Posted : 25/07/2017 4:13 pm
