Squeaky Fixy
[Closed] Squeaky Fixy
[#2902698]
Hi,
My fixy has developed a squeak, it sounds like its coming from the internal frame almost like a frame under stress or strain around the pedal, chain area.
It’s a aluminium frame with carbon folks, the noise seems to appear when I cycle only (not when i'm pushing)
With limited bike knowledge I thought it could be a bearing, a crack somewhere........
Any thoughts & advice would be appreciated please.
Thanks,
Hops
Posted : 30/06/2011 2:31 pm
bottom bracket is probably knackered
Posted : 30/06/2011 2:33 pm
Which leg of your sister's jeans have you rolled up?
Posted : 30/06/2011 2:39 pm
Isn't there and iphone app to help fix this?
You should be able to find your iphone somewhere in you overpriced satchel...
Posted : 30/06/2011 2:50 pm
Have you tried taking the bottom bracket out, cleaning and regreasing the threads then putting it back in?
Posted : 30/06/2011 2:52 pm
Do you only get the sound when sat on the saddle? 8)
Posted : 30/06/2011 2:58 pm
🙂 @ cookeaa
Posted : 30/06/2011 3:02 pm
Genius.
Posted : 30/06/2011 3:05 pm
I will try cleaning the bottom bracket as suggested, thanks.
There's no need for rolled up jeans when cycling in a skirt is perfectly acceptable- pockets too for iphones on days when the over priced satchel doesn't match the skirt! Try it!
Posted : 30/06/2011 6:39 pm
I ride fixed for my daily commute, but definitely don't fit the whole 'hipster' sh*t - however today a proper, pure blood hipster rocked up at the traffic lights. So skinny I couldn't tell if it was a bloke or a chick, even tighter jeans, rolled up, small d-lock tucked into the back of his belt, messenger bag - the ****in works.
Posted : 30/06/2011 9:21 pm
Who won the drag race?
Posted : 30/06/2011 9:26 pm
cookeaa - Member
Running in heels is difficult, isn't it?
Posted : 30/06/2011 9:27 pm
Assuming horizontal slot dropouts, check your track nuts are tight.
Posted : 30/06/2011 10:13 pm
Sounds like the bb or crank bb interface.
Or maybe your knees.
Posted : 01/07/2011 7:47 am
