Squeaking rotors wh...
[Closed] Squeaking rotors when wet
[#787830]
Does everyone suffer from the above? I have changed the rotors from Shimano to a Hayes and it still squeaks when wet. Is this something that I should just suffer with or is there any way to stop it/ Or are there any anti sqeak rotors that I could try
Posted : 15/08/2009 5:24 pm
Check you have enough pad left, clean the pads with a cloth, clean the rotor with a brake disc specific cleaner...
one of the above usually sorts it with my hayes 8)
Posted : 15/08/2009 5:45 pm
It's like that thing where you run a wet finger round the edge of a wine glass....
There can be 20 folk out on our rides and if its wet, they all squeel.... just 1 of those things. Although they are better with heat in them.
Posted : 15/08/2009 6:16 pm
All rotors squeal at some stage Get used to it.
Posted : 15/08/2009 6:22 pm
