Square taper, chrom...
[Closed] Square taper, chromed steel, 32T single ring chainset - where?
[#12012828]
Looking for a replacement chainset for my wife's Pashley - gearing is set up for someone who only ever travels downhill and can produce 400+watts for long periods.
We can't change the weight of the bike or the hub gears but a smaller front chainring might give her a fighting chance.
Basically this but with the smaller ring.
https://custom-junkies.com/steel-crankset-square-taper-chrome-plated-1-2x1-1-8-retro
Posted : 25/08/2021 4:04 pm
Can you not just use the one you have and stick a larger cog on the back?
As far as I am aware they all use the same three lugged cog that sturmey use.
Posted : 25/08/2021 4:50 pm
Try Spa Cycles, they seem to have a lot of niche stuff. Or SJS.
Posted : 25/08/2021 4:51 pm
Pou l'example
2.99 and 10minutes faffage seems like a win.
Get a few sizes and experiment?
Posted : 25/08/2021 4:55 pm
Depending on the chainline and current axle length you can run any old 4x 104bcd MTB triple chainset with a cheap ebay ring in the middle position.
Posted : 25/08/2021 4:57 pm
Try BETD.
Posted : 25/08/2021 4:58 pm
velosolo should have something suitable for a good price.
https://www.velosolo.co.uk/shopcrank.html
Posted : 25/08/2021 5:06 pm
Spa cycles. cheap, light, good looking, all teh options. Got one for the wife's bike, going to get one for my commuter too. Get a triple and put a chainguard/ trouser guard on the outer tabs.
It' so bloody marvellous spinning into town on her bike - few pedal strokes of leaving the house, think - "Oh, must tuck trews into socks.... No! Don't need to! Ha!" Bit like going for a ride in the rain with full mudguards. Bang on for a Pashley. Unless it's got a chainguard already?
Posted : 25/08/2021 5:20 pm
not chromed steel, though, so you can ignore all of that ^.
Posted : 25/08/2021 5:25 pm
Thanks everyone- few to look at. I did consider rear cog swap but it's already on somethign like a 20 and a 30% reduction would need 25-30t one which I wasn't sure was available for a hub gear but I'll check.
Biggest issue seems to be BCD and minimum chainring size on a lot of the 'road' options so I'll look at a double maybe and dropping the big ring off - hopefully chainlines will be ok as I don;t want to be mucking about with BB axle length if I can help it.
(thanks NedRapier - I'll look at that as a solution)
Posted : 26/08/2021 9:35 am
Thanks everyone- few to look at. I did consider rear cog swap but it’s already on somethign like a 20 and a 30% reduction would need 25-30t one which I wasn’t sure was available for a hub gear but I’ll check.
25t in stock here for £2.99
https://www.tritoncycles.co.uk/components-c9/fixed-cogs-lockrings-c65/hsl-series-3-dog-sprocket-p17395/s51882?utm_source=google&utm_medium=cpc&utm_term=sturmey-archer-hsl-series-3-dog-sprocket-size-18t-size-18t-husts18h&utm_campaign=product%2Blisting%2Bads&cid=GBP&gclid=CjwKCAjw95yJBhAgEiwAmRrutBl-xUSrOgAAknWMrdzRMsAUazvzFAHkgwQ9CVob0AvDYPE6FVD1zBoCFTAQAvD_BwE
Posted : 26/08/2021 10:20 am
Alloy not steel but SunXCD chainsets are amazingly retro looking. Go with cloverleaf chainrings for even more style (although these are available if fewer sizes).
https://www.veloduo.co.uk/collections/featured-products/products/sun-tour-sunxcd-crank-arms-50-4-bcd-110-bcd-stronglight-49d-ta-cyclotouriste
Posted : 26/08/2021 10:21 am
Going to give this one a go I think - 34t but looks like I can fine tune with the rear cog to a certain extent and this is cheaper than a separate crankset/ring/bolts purchase.
https://www.spacycles.co.uk/m8b0s109p4542/SPA-CYCLES-TD2-Stronglight-Dural-Single-Speed
Not chromed but I can polish them up further.
Posted : 26/08/2021 12:44 pm
