spreading the load,...
[Closed] spreading the load, so to speak?
 ton
[#10012059]
struggling with bike comfort again. tried a ism saddle, it has made a massive difference. but i need a wider saddle.
130mm across is too narrow.
i have never tried a wide saddle. widest i have used is a brooks b17 standard.which is 175mm iirc.
was thinking of tryng a cambium c19 which is proper wide.
so what i think i am asking is, should you use a wider saddle the heavier/larger you are?
Posted : 28/05/2018 11:08 pm
yes - the bigger you are the wider your pelvis thus the wider saddle you need.  You also need a wider saddle the more upright you sit
Posted : 28/05/2018 11:15 pm
Ill say, In the nicest possible way, I’m a fair bit narrower than you ton, and I won’t entertain anything less than 143mm. Go get measured.
Posted : 29/05/2018 12:20 am
Specialized dealer. Bum measurer. Do it.
Posted : 29/05/2018 12:21 am
Good padded shorts can make a big difference too
Posted : 29/05/2018 8:25 am
Might sound a bit daft but consider a women's saddle, they are generally wider than men's. But as above, get measured, without knowing that you'll just be guessing.
Posted : 29/05/2018 9:12 am
I was surprised to read recently that hip width and sitting bone width aren’t all that proportional - I get measured with one of those things.
Posted : 29/05/2018 9:23 am
Measure sit bone width in your riding position. Some manufacturers do multiple widths of the same saddle model.
Posted : 29/05/2018 9:49 am
