Spoke Length.....
[Closed] Spoke Length.....
[#1107459]
DT Swiss Calculator says i need 262's and 264's...............but.....could i get away with using 264's on both sides of the wheel, or would they be tooo long?!
Any help would be great!
Posted : 07/12/2009 11:06 am
oooohhhh. Could get to much spoke sticking out the top of you nipple and you may get to the end of the thread quick and not enable further dishing/truing?!?!
Whats wrong with using the right lengths?
Posted : 07/12/2009 11:08 am
You need to base your decision on the theoretical lengths to 1 decimal place.
You can go +/- 1mm either side of the theoretical length.
Roger
Posted : 07/12/2009 11:16 am
Similar question (sorry for the hijack!) - if the "right" lengths for the rear wheel I'm building are 259mm and 261mm, will I be OK with all 260mm?
Posted : 07/12/2009 11:27 am
I built a whole wheel with spokes theoretically 2mm too long and it's still fine... 🙂
Posted : 07/12/2009 11:28 am
I've also found the DT calulator to give some funny answers. I'd double check what you've got with the wheelpro calculator and then follow Roger's advice.
Posted : 07/12/2009 11:30 am
Yeh, I built a wheel last week using spoke lengths usggested by the dt calc. One side of the wheel has spokes that are a little too short, theres a small amount of the thread left exposed (ie not in the nipple) when the spokes have been tensioned properly. Dont think its a problem though
Posted : 07/12/2009 11:39 am
I used one of the online calcs to get sizes for a wheel, it totally cocked it up and I had spokes all 3mm too short. However that wheel is still going strong. It's the too-long ones that worry me, no room for adjustment.
Posted : 07/12/2009 1:09 pm
