Split in alu rear r...
Split in alu rear rim
[#13530672]
Would it be crazy to keep using this for light trail riding? The split is 20mm long. 32 spoke wheel.
Posted : 17/06/2025 12:46 pm
I can't post images yet. Here is a link
https://ibb.co/N2C4rMwf
Posted : 17/06/2025 12:48 pm
 Yak
Well, it's weaker now and will fail in more exciting way at some point. If you didn't have another wheel and had to get to the shops/work/whatever, then yeah given that it survived the rest of the ride when the damage happened. Would I ride it properly on trails knowing that it was there? No.
Posted : 17/06/2025 12:57 pm
Posted by: ahorizon
Posted : 17/06/2025 12:59 pm
Ha ha, ok. A vote for 'very crazy'.
Posted : 17/06/2025 1:42 pm
I would ride it slowly to the shop to buy another rim, but I don't think I'd take it offroad again. As Yak said it will fail worse next time, maybe not enough to cause a crash but probably enough to chew up the tyre on there and make you walk home.
Posted : 17/06/2025 1:47 pm
Is it a sticker?
Posted : 17/06/2025 1:49 pm
garethjw reacted
I've seen that sort of split extend massively when the tyre was pumped up, so approach with care...............
Posted : 17/06/2025 2:02 pm
The split has possibly been hiding behind that sticker for a year+. I noticed a little bump last time I was trueing the wheel, but didn't investigate further. I thought it was just a ding (which was visible with the sticker intact). This time while trueing, I decided to peel off the sticker and here we are. Next time I spot a ding I will be investigating properly.
Posted : 17/06/2025 2:48 pm
Front or rear?
If front, bin. If rear, I'd absolutely give it death, then put it on my wall as a badge of honour.
Posted : 17/06/2025 3:05 pm
