Specialized pizza r...
[Closed] Specialized pizza rack info
[#9368716]
Can anyone tell me the width of forks that a pizza rack will fit?
Hoping one might fit my vagabond and/or Dawes tandem
Posted : 07/06/2017 4:27 pm
'Any normal fork' is basically the answer, as long as it has mid-blade mounting eyelets and a hole at the crown for the centre stay. Should be fine on a Vagabond or your Dawes (as long as the mid blade mounts are there)
But I can measure the width to mounting points for you later if you like.
I've had them fitted to an AWOL fork (Duh) and Surly Disc Trucker forks, it needed a couple of small spacers on the DT fork.
Posted : 07/06/2017 4:34 pm
The vertical legs are spaced 160mm c-c at the top, maximum outside width of fork would be about 150mm. I've got them on my Longitude and had to spread the legs a bit (ooh er) to make it fit. Also have it fitting my touring bike with a couple of spacers.
Posted : 07/06/2017 4:44 pm
Great - 150mm width is what I am after, thanks for that info ta.
Posted : 07/06/2017 6:58 pm
Had my pizza rack for a while now and have just been using it with a cargo net so far as I'm struggling to find a bag that suits my needs.
The lomo in steezysiz's pic looks almost perfect good, but ideally I'd like 2 or 3 external pockets for things like wallet, camera, phone, map to have relatively quick access.
any ideas?
Posted : 08/06/2017 8:16 am
Specialized make a bag for the pizza rack don't they?
Posted : 08/06/2017 8:29 am
yeah YoKaiser, they do one, but I've not been able to find out much about it.
Posted : 08/06/2017 11:06 am
What extra info are you after?
[url= https://www.specialized.com/gb/gb/pizza-bag/126310 ]https://www.specialized.com/gb/gb/pizza-bag/126310[/url]
Any local Spesh dealers that have one in stock you could go an look at? There was one in my local shop last time I was in there I think, but didn't go and have a fondle.
Posted : 08/06/2017 11:08 am
looking to see
- how it opens,
- what side pockets it has / can it attach 'modules' for keeping the 'little things'
- how does it attach to the rack
I think I need to go fondling soon
Posted : 08/06/2017 11:31 am
- how it opens
roll/fold down top with strap by the look of it, not sure if that zip goes all the way around and also makes a kind of zipped lid arrangement too?
that zip on the side might be a side pocket?
Straps underneath I believe, ie: it straps to the platform from underneath
Fondle is always the best option 🙂
Posted : 08/06/2017 11:50 am
been using the pizza bag since october.
- how it opens,
>roll top. (there is no zip)
>two small external side pockets - i haven't really used them. I don't know what you mean by modules. the straps on the front might be good for this but they certainly aren't molle or similar.
EDIT: some useful netting pockets inside too.
>four velco straps underneath and the strap to fit the rack tombstone at the back. Mine is on a pelago rack so not quite as good fit.
Other bags to consider:
swift industries
surly
ILE
bigXtop (uk made)
freight baggage (might have shut down?)
Posted : 08/06/2017 12:00 pm
Update - actual space between fittings is about 135mm but looks like they should splay out to fit the 150mm wide forks okay 🙂
Posted : 11/06/2017 9:00 am
I use an ILE porteur bag for my commute. Fits well on the pizza rack. Three external pockets and a shoulder strap for when I want to take it with me.
Posted : 11/06/2017 10:49 pm
