specialized fox tri...
[Closed] specialized fox triad rear shock gone bonkers
[#5934402]
my 2012 shock has gone bonkers. the switch is loose but sometimes sits into position but never the 1 I want it in. lockout hardly ever works. will a service sort this prob or new shock needed.
Posted : 09/02/2014 9:35 pm
 LoCo
Service should sort it most likely seals have blown causing oil loss/ gas into oil
Posted : 09/02/2014 9:39 pm
thanks. it aint losing pressure or leaking though? but does seem a little stiff.
Posted : 09/02/2014 9:43 pm
 LoCo
Internal gas leak then perhaps or a jammed rod although that's usually in conjunction with an oil leak out of the adjusters
Posted : 09/02/2014 11:57 pm
