my friend asked if u can cut down carbon mtb bars? would it lose the strength?
Posted : 09/02/2014 9:41 pm
I cut my (previously) 800mm wide Easton Havoc Carbon 35mm bars down to 750mm the other day. All went fine. I used a lock on grip clamp as a guide and then filed it after.
The strength isn't affected. You're only cutting the end of, which is then covered by a lock on grip.
Posted : 09/02/2014 9:42 pm
thanks pal. ill pass it on unless hes readin this now.
Posted : 09/02/2014 9:46 pm
Don't breathe the dust though
Posted : 09/02/2014 9:54 pm
Some have reinforced ends, check before cutting.
Do it somewhere ventilated, wet the saw.
Posted : 09/02/2014 9:56 pm
I wont tell him that ha ha. hes better than me so ill b able to keep up with him if it disables him. thanks for the advice
Posted : 09/02/2014 9:58 pm
