Specialized Enduro ...
[Closed] Specialized Enduro bearing change question
I have an 06 Enduro, have just changed all the bearings, I need to reassemble the horst link (the one with the 2 really small bearings) at the chainstay, but can't figure out how to get the 2 flat washers in that sit between the bearings and the frame, It's a really tight fit. Anyone got any tips or advice? Cheers
Posted : 24/06/2012 9:09 pm
Hold them on the bearing then push the frame over the top, another pair of hands helps
Posted : 24/06/2012 9:17 pm
That makes it sound very easy! Will try a second pair of hands though ta
Posted : 24/06/2012 9:31 pm
Also check the bearings are seated right in
Posted : 24/06/2012 9:35 pm
Small piece of tape till its in place. My epic was the same. I'll drop it off at my lbs next time
Posted : 25/06/2012 6:38 am
I sometimes use a bit of grease to stick them in place.
Posted : 25/06/2012 7:06 am
^^ grease up (and some on the outside too) and slowly easy it all together.
It's best to pull / push the chainstay at a slight angle first (connecting slightly with one sides spacer) then straighten up - sometimes if the frame / chainstay are connected straight together the spacers are easy to get pushed off.
Posted : 25/06/2012 7:51 pm
