Hi I am replacing the bearings on a Stumpjumper evo 2012. Does anyone know if this is the same kit as for the normal Stumpjumper?
Dan
Posted : 24/02/2014 1:18 pm
Specialized only list stumpjumper fsr bearing kit so I believe they are all the same for 2012.
Posted : 25/02/2014 6:27 pm
Invest in a vernier caliper, measure the ones you take out and then buy from wherever.
The only thing special about them is that they're 'full complement' which means the balls are not caged within the races allowing more to be fitted.
You can use standard bearings if desperate but they might not last so long.
Posted : 25/02/2014 9:55 pm
