Scott Spark + RP23?
[Closed] Scott Spark + RP23?
[#3815403]
Just wondering, like, has anyone replaced the DT rear shock with a Fox unit?
Experiences/comments/practicality??
Posted : 28/03/2012 9:36 am
Nobody? 😐
Posted : 29/03/2012 10:04 pm
It's better. Simples. With boost valve it descends far nicer.
Posted : 29/03/2012 10:53 pm
 dlr
I have an RPL on mine, it pedals better in normal mode than the barely damped dt nonsense, with propedal on its great uphill then lockout for the road.
Main issue I had was sorting the bushings which were not the size in the manual nor stamped on my dt shock!
Posted : 29/03/2012 10:59 pm
22.2 x M6 both ends.
Simples.
Posted : 30/03/2012 11:26 am
Thanks, folks.
*credit card backs out of room s l o w l y * 😉
Posted : 30/03/2012 11:38 am
Do you not find you miss the remote lock out / traction mode? One of the best features of the bike IMO.
Posted : 30/03/2012 11:40 am
Tempted by this [url= http://www.mhw-bike.com/sale/mountainbikes/fullsuspension/40/scott-spark-40-black/white-2011 ]Scott Spark 40[/url] - any good?
Posted : 30/03/2012 11:43 am
The shock positioning means it's really easy to reach the propedal switch - try doing that on the fly on an Anthem... really difficult.
Posted : 30/03/2012 11:55 am
 Moda
I did mine 2 years ago, best change you can make. I used to run it with the pro pedal on at setting 3 all the time
Posted : 30/03/2012 12:26 pm
 dlr
Rickon: Not for me with my 2009 carbon 30. The dt ones said 22.2 as did the manual but the rear end was 22 and the front end 22.4 so I ended up with a set of 22 bushes from mojo then a pair of 0.2mm shims for a RC car motor (!) off ebay for the front
footflaps: You can reach it easily as mentioned above but you dont need it anywhere near as often as the fox shocks whether its a rp2/3/rpl actually have some form of low speed compresison damping unlike the dt thing
Posted : 30/03/2012 12:34 pm
Have to say I never really had any complaints about the DT original shock, I probably run it 95% in traction mode / 4% locked out and 1% fully open.
Posted : 30/03/2012 12:42 pm
