spacing a 2x crank ...
[Closed] spacing a 2x crank for 1x
[#6033162]
i've changed my setup from 2x10 to 1x10, but i've used a dedicated 2x10 crank to do this.... (XT M785 if you're asking)
now, i know the chainline on a 2x crank isn't ideal for switching it to 1x (it makes a devil of a noise when in the easiest gear with even the slightest suggestion of a bit of filth back there) So can i use some spacers on the new 1x setup get get a perfect chain line?
if so, what thickness of spacer should i use?
ta 😀
EDIT: this would be to 'push' the chain ring towards to the frame.. does that make sense?!?
Posted : 13/03/2014 4:31 pm
if you wanted to space it back to the midline of the cassette, you'd need 2.5mm (there's a 5mm gap between the chainrings, each are 2.5mm either side of the midline)
Or you could move a 2.5mm spacer from your BB from driveside to non-driveside, and move the whole chainset over.
But whatever you do, there's a good chance that it'll still be suboptimal / noisy when you're on the biggest rear cog, more so if you have a NW chainring. I have theories why
http://singletrackworld.com/forum/topic/1x10-noise-in-lowest-gear
Posted : 13/03/2014 5:12 pm
thanks... i'll do a bit more reading
Posted : 13/03/2014 6:05 pm
