Soul with narrow wi...
[Closed] Soul with narrow wide .....
Hi,
Just popped a superstar 34t thick / thin chainring on my mk 2 soul. (xtr chainset)
I normally wrap a bit of inner tube along the chainstay, in a squash racquet grip style.
It rubbed. I needed to cut a small whole in the tube as there is only about 1mm clearance for the teeth at the stay.
Just a heads up.
Daniel
P.s I'm running the appropriate BB spacer. So all as it should be.
Posted : 01/06/2014 2:39 pm
Was that in the middle ring position on a triple?
Posted : 01/06/2014 11:00 pm
I ran a 36 middle on my Soul, it had a decent amount of clearance, the thick/thin ring;ll be thicker but it wouldn't be enough to make it a problem.
(that said I wouldn't wrap an innertube round that part of the chainstay either)
Posted : 02/06/2014 12:02 am
Yep, middle ring option on an xtr triple.
Lines up with the old mrp top guide perfectly (bb mounted in stead of spacer).
Just closer than I thought it'd be.
Posted : 02/06/2014 12:12 pm
