Solo air not adjust...
[Closed] Solo air not adjustable travel?
[#4817503]
Hi,
Was gonna order some 29er Sids In black but only available in 120mm.Been told they can't be adjusted down and I will need to buy a new cartridge! Damn! Not trying to doubt a knowledgeable source but really? Anybody got any black 29er rebas or Sids in 100mm?
Thanx,
Max
Posted : 30/01/2013 11:37 pm
Normally just a case of moving spacers around. I bet you can.
Posted : 30/01/2013 11:39 pm
 LoCo
You need a new air spring assm on the 2013 solo airs, as always we can supply parts
Posted : 30/01/2013 11:40 pm
Hi,
Thanx Loco,what's the cost of the cartridge and fitting?
Thanx,
Max
Posted : 30/01/2013 11:42 pm
 LoCo
RRP is £70 ish on parts, ( we'll be considerably less than that) and fitting minimal labour charge and you'd get a lower service with bush check and fresh lower lube at same time, drop us a mail and Can give you a proper quote as on phone now
Posted : 30/01/2013 11:46 pm
Ok,thanx for that.I will have a think and consider my options.
Max
Posted : 31/01/2013 12:13 am
