So what is the diff...
[Closed] So what is the difference between 9/10/11 speed...
[#7160566]
... on front chain rings (road)?
Posted : 28/06/2015 10:10 pm
No idea.... But I run 9 slx speed rings on my 11 speed 105 and they work perfectly
Posted : 28/06/2015 10:18 pm
Width, I think. At a guess, you'll get more chainsuck if you do the above.
Posted : 28/06/2015 10:24 pm
Yeah I think the 9 speed cranks (double) were about 1 mm further apart. The 11 speed chain is slightly narrower. Apparently the shifting ramps on 11 speed cranks are optimised to improve shifting but as I said the 9 speed rings work and shift absolutely fine and no chain suck for me so far.
Posted : 28/06/2015 10:38 pm
Differences:
9 to 10 is 1
10 to 11 is 1
9 to 11 is 2
11 to 10 is -1
10 to 9 is -1
11 to 9 is -2
Pretty sure thats all the differences and combinations...
Posted : 28/06/2015 11:24 pm
9 to 10 is actually 0.999999 recurring, technically.
Posted : 29/06/2015 5:38 am
IIRC, nominally derailleur chains are the same internal width; the external width is shaved down to fit more sprockets in, which is why the 9s rings ^^ will work on 11s, but may be prone to chainsuck (the narrower chain could catch between the rings if they are further apart)
Posted : 29/06/2015 6:15 am
Ok, so I'm currently 9sp 50/34 on a 9sp 27/12 cassette.
I'll be going 11sp 105 50/34 on a 9sp 25/12 cassette. Bugger all real world difference?
Posted : 29/06/2015 7:07 am
@kryton57 - thats what i use, no problems, although i think its slightly more rattly up front, could be the 9speed links on the 11 speed rings, or could be the 11speed front der. is a little narrower.
shifting is perfect up front and no issues on the rear either.
Posted : 29/06/2015 9:55 am
Reggiegasket 9 + 1 = 10.
Posted : 29/06/2015 10:26 am
