Snapped chain
[Closed] Snapped chain
Snapped my first chain 2 months ago after doing approximately 1400 K in 6 months mostly Golfie,Dunkeld type of riding,now I have just snapped my 2nd Shimano Deore chain after only 2 months. The chain is cleaned every two rides using the Park chain cleaner and a heavily diluted Screwfix degreaser has anyone any idea why this is happing as both chains haven't even reached .75 wear
Posted : 10/04/2017 11:35 am
Not fitted correctly is the usual cause. Did you use a new pin?
Posted : 10/04/2017 11:38 am
I just find Shimano chains to be absolutely rubbish (and nothing to do with joining pins)
Posted : 10/04/2017 11:42 am
Used a power link. Fitted the chain the same way I have always done round the big ring front and back to measure it
Posted : 10/04/2017 11:43 am
Shimano chains have always had a reputation for snapping. IME most snappage is related to rough shifting technique, trying to shift multiple gears while mashing on the pedals.
Posted : 10/04/2017 11:46 am
Mashed shifts while climbing have been the cause of most my snapped chains
Edit, just beaten to it ๐Ÿ˜‰
hols2 - Member
but what's never been explained is why the same people can use another brand's chain for years with no issue?
Posted : 10/04/2017 11:48 am
If shimano do have this reputation my guess is that it's because of how they join - introducing human error. Some early ones were fragile though.
It's nothing to do with wear IME (as a mechanic).
Posted : 10/04/2017 11:52 am
Dunno but when splitting the chain to get rid of the damaged bit, it was evident the side plate had deformed on a sprocket tooth, twisting that link. The damage was nowhere near an existing join
Posted : 10/04/2017 11:53 am
If you're not running 1x, switch off the clutch on the mech.
Gives a lot more freedom in mashing gears IME.
Posted : 10/04/2017 11:55 am
cynic-al - Member
In the OP and my own experience, the break isn't anywhere near the joining pin (which the OP didn't use anyway). So unless it's somehow translating a wonky force half-way around the chain, I'm not buying it (last one I had was 3 rides old when it went, the replacement Sram is over 2 years old with no issue so far)
Posted : 10/04/2017 11:56 am
Fair enough, still not statistically relevant though.
Posted : 10/04/2017 11:58 am
Rough shifting
Posted : 10/04/2017 12:04 pm
Soz, didn't realise we were going for deep statistical analysis.
Posted : 10/04/2017 12:11 pm
Anything less is just anecdote and so meaningless
Posted : 10/04/2017 12:14 pm
Is this total balls as well then?
hols2 - Member
Rough shifting
Didn't break though ๐Ÿ˜‰
Posted : 10/04/2017 12:17 pm
When you look how tiny bike chains are it's no wonder they can sometimes snap under lots of torque. Not always a faults pin or joint. Just too much power sometimes.
Posted : 10/04/2017 12:31 pm
I have always avoided shimano chains since a brand new one snapped on me in 1994.
Never had a problem with sachs chains, whose business were bought out by Sram, aside from once when I got chain suck, pulled the chain out and then it snapped shortly after - must have bent it.
Posted : 10/04/2017 12:52 pm
Aren't shimano made by KMC?
I've snapped shimano and sram - could be just a faulty chain?
Posted : 10/04/2017 12:56 pm
The simplest explanation is just plain bad luck. I point you in the direction of the [url= https://en.wikipedia.org/wiki/Clustering_illusion#References ]Clustering Illusion[/url].
Posted : 10/04/2017 1:10 pm
rjmccann10 has it
I caveated my response...also over 10 years of wrenching it's more relevant!
Posted : 10/04/2017 1:26 pm
