Snap ring pliers
[Closed] Snap ring pliers
Need a set of snap ring pliers to get the external circlip off the motion control leg on my pikes - recommend me a good set please 🙂
Posted : 21/09/2009 7:37 pm
Maplins do a seviceable set for approx £10. Will do internal and external circlips.
Posted : 21/09/2009 7:47 pm
Please note that there is a difference between a snap ring and a circlip. If you order on line be sure to order corectly. Snap ring pliers have small flat pads on the tips circlip pliers have round tips.
Posted : 21/09/2009 7:54 pm
I got mine out of Halfords. They're the wrong way round for Pikes but they do work with some effort - I originally bought them to strip down a set of Avid Juicys.
Posted : 21/09/2009 9:12 pm
I got a set with changeable heads (internal/external/bent) from Ebay for about 4GBP, just used them to rebuild my Gfs Recons. If you live in Exeter you can borrow them...
Posted : 21/09/2009 9:18 pm
2nd vote for the Maplin set. Comes with different adaptors for inner/outer clips and different sizes.
Posted : 21/09/2009 9:19 pm
I've just ordered some of these, they've not arrived yet but given the price I'm expecting they might be made of cheese.
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=350141463721&ru=http%3A%2F%2Fshop.ebay.co.uk%3A80%2F%3F_from%3DR40%26_trksid%3Dp3907.m38.l1313%26_nkw%3D350141463721%26_sacat%3DSee-All-Categories%26_fvi%3D1&_rdc=1
Posted : 22/09/2009 7:24 am
If you're only going to use them occasionally the Maplin/ebay ones with changeable heads to convert from internal to external should be OK
They're also available from Machine Mart if that's more local to you
Posted : 22/09/2009 7:29 am
I bought some of the cheap interchangeable head ones from eBay and they were rubbish. They would work to a point and then just start distorting - it made the job much more difficult than it needed to be. Kept having to bend them back into shape after each circlip.
They are in the bin now & I am gonna get a decent set from somewhere like Screwfix.
Posted : 22/09/2009 8:14 am
I have to agree with stumpy. I had exactly the same experience with them distorting all over the place.
I also found that the pins themselves were over-large for some of the circlips.
I bought a pucca set and they're much better. I muck through with the one set, doing both internal opening and external opening circlips.
Posted : 22/09/2009 8:35 am
