SLX brakes - remove...
[Closed] SLX brakes - remove oil ?
The rear brake is great but feels a bit too sharp - not enough lever travel bofore fully locked. How can I soften it? remove a bit of oil from the reservoir?
Posted : 23/05/2009 5:44 pm
A mate had a similar problem with his Hayes 9s he ended up using a syringe to inject a bubble of air into the caliper bleed screw
Posted : 23/05/2009 5:47 pm
Is it on a big rotor? Could you put a smaller rotor on rather than sabotaging it?
Posted : 23/05/2009 5:58 pm
It is on a 160mm rotor. I reckon I can remove a drop of oil.
Posted : 23/05/2009 6:07 pm
Normally its the other way round-help my brakes are pants.
And this guy says they too good! LOL
Adjust the lever reach?
Posted : 23/05/2009 7:37 pm
My brake was soft, I could pull the lever all the way in with one finger rather too easily. Re-bled the brake and forced oil into the system then. I probably gave it too much juice so it moves some 3mm before engaging.
Zaskar, it's stupidly simple to rectify (start at the bottom and work upwards - the old-fashioned way with a siringe, hose and swearbox).
Posted : 24/05/2009 6:18 am
