SLX Brake Clicking
[Closed] SLX Brake Clicking
[#2463615]
I have found that my rear SLX brake is clicking when ever I pull the lever. It comes from the calipers and i'm not sure why. I think the pads or rotor is hitting against something but i'm not quite sure.
Help?
Posted : 12/02/2011 10:22 pm
Often the sound of a sticking piston as it suddenly releases and takes up the gap, can sometimes be felt at the lever too.
Posted : 12/02/2011 10:57 pm
Is the spring 'clip' piece that splits the pads, bent slightly and sticking pround of the pad surface?
Posted : 12/02/2011 11:02 pm
Loose bolts holding the caliper down or loose bolts holding the adaptor on???
Posted : 12/02/2011 11:13 pm
 CalD
I've had this aswell and as coatsey says its the piston sticking, take pads out and pump pistons out almost all the way, clean, then put a drop of mineral oil on each one so it slides freely.
Posted : 12/02/2011 11:19 pm
