Fun and games again.
2 month old reverb is holding pressure, but now quite slow when extending from a compressed state back to full height.
Previously had problems with another whereby it wasnt holding pressure thus failed seals, but this one has got slower over the last couple of weeks.
Does bleeding help the speed at which is returns?
I thought the speed was controlled by adding pressure?
So did I. Checked it and its held at 240psi for the last 4 weeks without a problem.
Have you tried adjusting the speed control located from fast to slow and back to fast to see if it makes any difference?
If there is any air in the system it would affect the speed, if you have a bleed kit I would try bleeding it as it is a simple process.
the speed return rate dial thingy on the actuator?
Yup, checked that too
Lube the seal. If it gets dirty / dry & dusty it can add friction and thereby get slow.
Also ensure your have not crushed the tube by clamping it up too tight.
I ride mine all year round in all weather and just had it serviced by TF after 13 months of use/abuse - they said it was fine. So they do seem to work well.
If you have issues send it to TF - very fast and good service.
Thanks will lube the seal as it has been hosed...ooops should I say sponged down a few times recently. Will also bleed.
Thanks everyone. Just love STW, its the only forum I know about where you can post a question and have answers within minutes!
Ps. What type of lube for the seal?
It's two months old, so Fishers would be the place for it to go at the moment
Fishers dont want know. I have to send it back via retailer which is in germany...so last resort. Will try above ideas first. Its working, its just a bit slow.
variflex -Ps. What type of lube for the seal?
My mate the Inuit suggests low viscosity KY, and says dont bother kissing it.
A clean and pushing the pressure up slightly higher (a recent return from SRAM on another reverb I have was 300PSI) and a bleed has sorted it. Looks like there may be an air leak as when bleeding alot of air was released. Will see how it goes. It could just be that when I shortened the hose when new I didnt bleed properly....time will tell.
Many thanks All
Sounds like it needs bleeding.
Mine slowed down but then I bled it and now it's fine 🙂
Mine has a similar sounding problem to yours recently after 9 months use, I bled it- really easy- and works like new again!
