Had some specialized low pro mags which have a nice flat platform but the bearings gave up after an ok ish life. In trying to fix them I've come to the conclusion its not a great design. Replaced them with some nukeproof electrons but after a few rides I'm finding the raised middle where the bearings are a bit annoying. So being a bit fussy I'm looking for something slim with a flat platform. Anything out there? Did specialized ever make these:
http://m.pinkbike.com/news/Specialized-Prototype-Pedals-Crankworx.html
HT Components AE01 is very thin and very flat. Also a bit crap, terrible bearing design, they're dying as soon as you open the box. But you can still get a decent life out of them.
Yeah my ae01's have died too... The delta from superstar look good, might be available as something else too? Are on one still doing them el guapo pedals?
I love these not the cheapest but they work.
http://www.burgtec.co.uk/category/products/pedals/
DMR Vault - Love em but not cheap, Superstar Nano tech flats (cheap and light with ti spindles on free upgrade at the mo).
Superstar nanos, nuke proofs or bit more spendy DMR vaults.
Vaults are even better than flat, they're concave!
Spank spikes? Pricey though
passtherizla - MemberYeah my ae01's have died too..
If it's just the shit bearing on the end, just get rid of it- pack the cap out with washers instead to the right sort of thickness, locktite the end nut on, and let the pedal float. Seems to work exactly as well as the original parts.
NS Bikes Aerial Pro
Deity Decoy are my choice for life.
Magnesium LT ones too are lighter, replaceable pins. super flat.
Superstar Ultra Mags for me.
Sorry just to clarify, I'm trying to avoid anything with a power bulge around the bearings. The superstars seem to have a bulge as do a few others mentioned. What are those on ones? DMR Vaults might be possible but they are a bit speedy.
Really don't want this bulge in the middle.
[img]
[/img]
What shoes are you wearing?
I have the same pedals and can't feel the bump through my (admittedly very padded) Five10 Impacts.
On One park hill flats (allegedly) out in the next couple of months for £50.I'm definitely having some.
Unfortunately the bulge is there due to the reduction in the overall height of the pedals (making them slim) therefore you will need to have normal sized pedals that are flat. What about shimano saint, they aren't to bad.
Yeah I have Saint pedals, they are definitelt pretty flat in the middle with a slightly concave overall sahpe.
I wear all sorts of shoes on my Saint equipped SS and have always been comfortable.
New On Ones presumably? Pins look like they were designed not to grip, I guess we'll see.
Change the pins?
Hope F20s don;t have that bulge and are pretty slim, and reliable. They need the alternative pins fitted for best grip but that's easy done. Not cheap though.
Northwind - Member
Yes those pins look like they're designed by someone with longevity and ease of maintenance in mind rather than grip. Non threaded 4mm studs are bad enough but those things looks like 6mm diameter with radiused corners. I'd wager them not offering much grip like that. The pedals on the other hand look great.
The pins on brand new Vaults and the soles on VXi 5.10s stick together so well that it's impossible to lift your foot off without either the front or rear pins pulling the pedal up so it spins around when all you're trying to do is slightly adjust your foot position. I was very glad when the pins fractionally rounded off and the grip levels dropped to something more useful!
