CX brake pad, which...
[Closed] CX brake pad, which fitting?
[#6202709]
Looks like I need to replace the pads on my CX canti brakes and being used to discs, I'm a bit confused as to which type of fitting I need... 😕
I've got Tektro CR520 cantis and I know I [b]dont[/b] need a cartridge pad, but I'm not sure if I need a threaded or canti fitting?
Anyone know the answer? These are the brakes in question btw.
Posted : 19/05/2014 9:35 pm
They're just standard v-brake pads in that pic
Posted : 19/05/2014 9:40 pm
V-brake? Now you're throwing another option at me!
So are v-brake different to these, which are meant to be suitable for cantis?
[img] ?w=430&h=430&a=7[/img]
Posted : 19/05/2014 9:59 pm
As Simon said, yours just have v-brake pads. The conical washers will allow you to toe-in the pads easily.
Posted : 19/05/2014 10:02 pm
I'm confused to buggery now 😕
So let me get this straight, v-brake pads are fine for use in cantilever brakes? Remembering v-brakes of old, I thought they all used a cartridge pad. Maybe not then
Furthermore, those (red, blue, grey etc) pads I linked to above wont work?
But I would be best off with something like these instead?
Posted : 19/05/2014 10:12 pm
The canti pads you have pictured definitely won't work. The ones you have pictured underneath will.
Posted : 19/05/2014 10:18 pm
Ahh thanks for the confirmation, I'm slowly getting it now 🙂
So these type (below) are for v-brakes and therefore should also work
Posted : 19/05/2014 10:29 pm
 Spin
Yes.
Posted : 19/05/2014 10:34 pm
On closer inspection, the pads on your brakes do look like 'threaded' cantilever brake pads. They are a bit shorter than v-brake pads.
Just do a google image search for 'threaded canti brake pads'
Posted : 19/05/2014 10:36 pm
Got the bike sat behind me and the stock pads that came with it do seem quite short, certainly shorter than those red v-brake pads I linked to above.
I think the black Kool Stop ones (up there^^) have the same fittings and the pad is also a little shorter, and perhaps the pad material is also a little thicker.
Posted : 19/05/2014 10:41 pm
 Spin
V-brake pads come in different lengths. I find the shorter ones slighly easier to set up on crosser rims with a shallower sidewall.
Posted : 19/05/2014 10:57 pm
Thats good to hear as I went for the slightly shorter v-brake fitting.
Posted : 21/05/2014 4:31 pm
